AXL - CUCM10.5 - Can't execute SQLQuerry
Enric92
I try to querry the AXL but i receive a SoapEnv: Fault
Send:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.5">
    <SOAP-ENV:Body>
        <executeSQLQuery sequence="1416839392254">
            <sql>select pkid, name from devicepool</sql>
        </executeSQLQuery>
    </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
    <soapenv:Body>
        <soapenv:Fault>
            <faultcode>soapenv:Server</faultcode>
            <faultstring>error: The document is not a executeSQLQuery@http://www.cisco.com/AXL/API/8.5: document element namespace mismatch expected &quot;http://www.cisco.com/AXL/API/8.5" got &quot;&quot;</faultstring>
            <detail/>
        </soapenv:Fault>
    </soapenv:Body>
</soapenv:Envelope>
Something seems wrong?
Thanks !
dstaudt
I believe the way the namespace is declared, as 'ns', that the request element name should be 'ns:executeSQLQuery'
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:executeSQLQuery sequence="?">
         <sql>?</sql>
      </ns:executeSQLQuery>
   </soapenv:Body>
</soapenv:Envelope>
dstaudt
   <soapenv:Header/>
   <soapenv:Body>
         <sql>?</sql>
   </soapenv:Body>
</soapenv:Envelope>
That's right, it's working,
Thanks a lot!
