CER set ERL for Unlocated Phone
peterputt
if I'm trying to set the ERL of a unlocated phone that has no ERL set yet (default), using a PUT to cerappservices/service/unlocatedphone
<updateUnlocatedPhoneRequest>
<PhoneMACAddress>11-22-33-44-55-66</PhoneMACAddress>
<AssignERL>ERL3</AssignERL>
</updateUnlocatedPhoneRequest>
I'm getting this error:
<unlocatedPhoneResponse>
<status>Invalid entry</status>
<message>Could not set zone to Discrepancy phones</message>
</unlocatedPhoneResponse>
Is there a way to initially set an ERL?
Peter
5 Replies 5
Alexander Stevenson
Hello @peterputt,
Please see this reference:
Cisco Emergency Responder Configuration API
Errors and Troubleshooting
- ERL Management
ERL Assignment
The ERL Assignment section contains that call "PUT http://{CER-IP}/cerappservices/service/unlocatedphone"
Notes:
  1. Make sure you have unlocated phone entry available which you want update it.
  2. ERL should be present in CER server which you want to update it.
  3. Test ERL are not allowed to assigned.
For all the resources associated with this API, please see here --> Cisco Emergency Responder
Cisco Emergency Responder reporting API
Hope this helps!
Hi alexstev,
Thanks for your reply.
The PUT request is working if I change the ERL e.g. from ERL2 to ERL3 - so the conditions are met. It is just not working if the origin ERL is default.
Changing from default to something else should be possible, right? Did that work on your side?
Peter
Looks like CER V14 has the same issue.  Did you ever work around it?
No. I get rid of CER and built my own solution using ECCP.
Very creative.  Thanks
