Check call forward privileges when updateLine
CHRISTIAN END
i wrote a function to update a line call forward all with given only the IP address of a device. Background is, that the devices are Third-Party SIP Devices and i want to have set the CFW All directly into the CUCM.
The main issue at this point i got, that when i did the updateLine request with the destination and CFW All CSS for a line, i have no check about the CFW privileges.
Example:
The CFW CSS has the call privilege to forward only to internal numbers  and national numbers.
Now i did a updateLine request with a international number. It was set successfully.
Is there any way to handle this? Is there a function to prove the privileges before setting the CFW All Destination?
Thanks for any replies...
Christian
dstaudt
Not aware of any official APIs that would allow for testing dialed numbers for validity against the configuration/dial-plan, as described.
The Dialed Number Analyzer service and function in CUCM Serviceability does perform this kind of analysis, though via admin web UI - it's possible you could adapt the web functions that this UI uses for your app, though this would not be officially supported.
