Cisco CUCM Query with C#
daemon.amini1
Hi i have a problem using C# for querying CUCM, i got an error:
System.Net.WebException: The remote server returned an error: (599).
   at System.Net.HttpWebRequest.GetResponse()
Here is my code:
HttpWebRequest req = (HttpWebRequest)WebRequest.Create(@"https://172.20.0.101:8443/axl/");
            req.ProtocolVersion = HttpVersion.Version10;
            req.Method = "POST";
            req.Host = "172.20.0.101:8443";
            req.ProtocolVersion = System.Net.HttpVersion.Version10;
            req.ContentType = "text/xml";
            req.Accept = "text/xml";
            req.Headers.Add("Authorization", "Basic " + Convert.ToBase64String(System.Text.ASCIIEncoding.ASCII.GetBytes("test:admin123")));
            req.Headers.Add("SOAPAction:CUCM:DB ver=10.5");
            req.Credentials = CredentialCache.DefaultCredentials;
            string mes;
           mes = "<SOAP-EN:Envelope xmlns:SOAP-EN=";
            mes += "\"http://schemas.xmlsoap.org/soap/envelope/\"";
            mes += "xmlns: ns =\"http://www.cisco.com/AXL/API/10.5\">";
            mes += "<SOAP-EN:Header/>";
            mes += "<SOAP-EN:Body>";
            mes += "<ns:executeSQLQuery sequence = \"1\">";
            mes += "<sql>SELECT * FROM Device</sql>";
            mes += "</ns:executeSQLQuery ></SOAP-EN:Body></SOAP-EN:Envelope>";
            System.Net.ServicePointManager.ServerCertificateValidationCallback = delegate (object sender, X509Certificate certificate, X509Chain chain, SslPolicyErrors sslPolicyErrors) { return true; }  ;
            byte[] buffer = System.Text.Encoding.UTF8.GetBytes(mes);
            req.ContentLength = buffer.Length;
            Stream s = req.GetRequestStream();
           // s.Position = 0;
            s.Write(buffer, 0, mes.Length);
            s.Close();
            try
                WebResponse resp = req.GetResponse();
                s = resp.GetResponseStream();
                StreamReader sr = new StreamReader(s, Encoding.UTF8);
                string outputString = sr.ReadToEnd(); //Just output XML response
                richTextBox1.Text = outputString;
                sr.Close();
                s.Close();
                resp.Close();
            catch (Exception ex)
                string excep = ex.ToString();
                richTextBox1.Text = excep;
0 Replies 0
