Delete User from CUC using AXL?
Hi, my goal is to create a script to delete a user from Cisco Unity Connection Administration (CUC) using the AXL API. This is the API I've been using for CUCM automation, I'm assuming it's the same one for CUC?
The user is an LDAP user synced from Active Directory, therefore the userid should be the same in both CUCM and CUC. Can I simply use the removeUser cmdlet, or do I need to use a different cmdlet or API entirely? I am using version 12.5 if it matters.
dstaudt
See CUPI: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/REST-API/CUPI_API/b_CUPI-API/b_CUPI-API_chapter_01.html#id_35653
Note, if CUC is using AD/LDAP as its user-store, then you would need to use any APIs for the AD/LDAP itself to manage users.
thedd
Level 4
Level 4
You will have to use Cisco Unity Connection Provisioning Interface (CUPI) API which is not the same as CUCM AXL
