Problem with updateServiceProfile request
jdrinkwater
Level 3
Level 3
I am trying to update Service profile but cucm server returning error. It only happens in 12.5 release.
I am getting axlcode of -1 when I try to set the secondary or tertiary of  Video conference scheduling portal profile. No problem setting primary though. Can someone help me?
Here is the request and response I am using.
<axl:updateServiceProfile xmlns:axl="http://www.cisco.com/AXL/API/12.5">
<name>serviceprofile1</name>
<serviceProfileInfos>
<serviceProfileInfo>
<profileName>Video Conference Scheduling Portal Profile</profileName>
<primary>primaryVideo</primary>
<secondary>secondaryVideo</secondary>
<tertiary>
</tertiary>
</serviceProfileInfo>
</serviceProfileInfos>
</axl:updateServiceProfile>
<?xml version='1.0' encoding='UTF-8'?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server</faultcode>
<faultstring>
</faultstring>
<detail>
<axlError>
<axlcode>-1</axlcode>
<axlmessage>
</axlmessage>
<request>updateServiceProfile</request>
</axlError>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
dstaudt
I was able to reproduce the issue, and created defect CSCvq97986
Added a Python sample showing a workaround using <executeSQLUpdate> to the project here: https://github.com/CiscoDevNet/axl-python-zeep-samples
jdrinkwater
Level 3
Level 3
Thanks David as always!! I will keep on eye on the fix.
Jung
thedd
Level 4
Level 4
What happens if you only use the fields you want to use?
I only add field to my axl that are required or i want to use.
Do you have the same error when using this:
