EMAPI, get device IP
KandyOtero
Level 2
Level 2
I'm working with EMAPI. Is there any api/method/xml Request to get the ip associated to device on UCCM login?
Best Regards Kandy
tinghche
Level 6
Level 6
You can use RisPort SOAP Service to get the ip address for registered device.
For details, it's in the same document with EMAPI under the session of Serviceability XML
Howard
Thanks Howard
I'm trying to use the soap service, but I have problems with the certificate. How must import the certificate to my keyStore to prevent this errors?
Thanks for all
Hi Kandy,
You can check out this post with step by step instruction for your reference.
https://developer.cisco.com/site/collaboration/management/axl/learn/how-to/axl-java-sample-application.gsp
Howard
