Get PKID of inserted row
Gordon Ross
Level 9
Level 9
When inserting a row via AXL SQL, is there a way to get the PKID of the newly inserted row?
GTG
Please rate all helpful posts.
Geevarghese Cheria
Hi GTG,
Here is a snip of SQL to get the PKID of a phone.
select pkid from device where name='SEP000000111111'
This will return the PKID, or UUID, of the phone with MAC address 000000111111
Download  yourself a copy of the data dictionary for whichever version of Communications Manager you are working with.
If you have access to the COmmunications Manager console directly or through an SSH  client you can run sql commands and see the returned values from there  before writing them into your code.
In the command line the query would look something like this:
run sql select PKID from device where name = "SEP000000111111"
Reference - Finding UUID for CUCM Objects
Thanks and Regards,
Geevarghese
I know how to do that, and I do have the CallManager Data Dictionary by my side - all 1,000 pages of it.
In some databases, you can do a "INSERT INTO table (columns) VALUES (....) RETURNING pkid" and the insert command would give you the pkid of the just inserted row.
I was hoping to avoid the round-trip of issuing an INSERT, then having to do a separate SELECT.
GTG
Take a look at this sample SQL query, you should be able to get the pkid using newid() function.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<axlapi:executeSQLUpdate sequence="1" xmlns:axlapi="http://www.cisco.com/AXL/API/7.0" xmlns:axl="http://www.cisco.com/AXL/7.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.cisco.com/AXL/API/7.0 axlsoap.xsd">
<sql>
insert into device (fkPhoneTemplate,fkDevicePool,tkclass, tkpreemption, tkdeviceprofile, tkmodel, tkdeviceprotocol, tkproduct, description, tkstatus_mlppindicationstatus, name, pkid) values ('Standard 7941 SCCP','default',1, 2, 2, 115, 0, 115, '', 0, 'Cisco 7941', newid())
</sql>
</axlapi:executeSQLUpdate>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Howard
