Failing to clear primary and IPCC extension using Python - CUCM
I am working on a python script to migrate CUCM users from one cluster to another. I am able to change the value of home cluster and the IM&P enable user value, but I haven't figured out how to clear the primary and IPCC extensions. This is what I was trying.
# Execute the updateUser request
resp = source_axl.updateUser(
    userid = userid,
    homeCluster = False,
    imAndPresenceEnable = False,
    primaryExtension = None,
    ipccExtension = None
I tried setting the extensions to {} or [], but no joy.
BjoernMartin
Hello Eliot,
that's easy
I think that you are using the python "zeep" module....
then the request should look like this.
updateUser(**{'userid': userid,
                       'homeCluster': 'false',
                       'imAndPresenceEnable': 'false',
                       'primaryExtension': {
                           'pattern': '',
                           'routePartitionName': ''
                       'ipccExtension': {
                            '_value_1': '',
                      'ipccRoutePartition': {
                          '_value_1': '',
If you have further questions, please get in touch
https://developer.cisco.com/docs/axl-schema-reference/
BjoernMartin
Hello Eliot,
that's easy
                           'pattern': '',
                       'ipccExtension': {
                            '_value_1': '',
                          '_value_1': '',
Perfect, thanks! Yes, I am using 'zeep'. I was looking at the AXL schema reference, but I was having trouble interpreting it. Here is exactly what I did, and it worked.
                **{ 'userid': userid,
                    'pattern': '',
                    'routePartitionName': '',
                'ipccExtension': {
                    '_value_1': '',
                    'uuid': '',
