Get Linegroup from Device (name)
Hello there,
I try to get my SQL the Line Group out via the AXL API.
I want to specify the device name and get the Line Group.
Can someone to call the SQL string?
Gruß Matthias
istibekesi
This might help, from the data dictionary:
SQL something like this:
run sql select lg.name, np.dnorpattern  from linegroup lg, linegroupnumplanmap lgnpm, numplan np where lgnpm.fklinegroup = lg.pkid and np.pkid = lgnpm.fknumplan and np.dnorpattern = '3335'
name     dnorpattern
LG_Unity 3335
Thanks for your answer.
Is it alternatively possible to get from the Windows user to the Device Name?
I'm not sure I understand your question... Windows user and Device Name are independent, not linked to each other, unless you have your own naming convention.
lior look
Level 5
Level 5
Hi Matthias,
I'm not sure if I understand your question.
Do you want to send an device's name and get the line group who contains the device?
Did you mean that?
