GET operations for Access Points in CER
Using the API, is there a way to obtain a list of Access points with their assigned ER Locations? I checked the documentation, and there's no support for GET operations with Access Points, maybe we are missing something?
If truly the API it doesn't support access points read operations(it supports switches and IP subnet why not access points as well), is there a way using the API to determine what ER Location is assigned to what Access Point?
dstaudt
The CER Configuration API seems to have this operation:
GET http://{CER-IP}/cerappservices/service/accesspoints
https://developer.cisco.com/docs/cer-config/#!erl-management/erl-assignment
dstaudt
