getGatewayEndpointAnalogAccess, updateGatewayEndpointAnalogAccess / removeGatewayEndpointAnalogAccess & name tag
stephan.steiner
Last one for this week. I fell flat on my nose trying to update/delete analog ports on a gateway. The command does take the usual name/uuid combo, but unlike every other object I've dealt with so far, the uuid comes from another object level than the name (and it actually applies to the get, too). The object looks like this:
<gatewayEndpointAnalogAccess uuid={somepkid}>
<some gateway data here>
<endpoint uuid={somepkid}>
<name>
</endpoint>
</gatewayEndpointAnalogAccess>
For a get/update/remove you can use <uuid>somepkid</uuid> and it doesn't matter where you take it from (I wrote somepkid because it is the same in both gatewayEndpointAnalogAccess and endpoint). But if you're using the name, you must use the name from the <endpoint>. You could now argue that there's no name tag on gatewayEndpointAnalogAccess, which is true. However, given that it's not your standard way of working, perhaps a little note in the documentation could help other people from bumping their head.
0 Replies 0
