GetLdapSyncStatusRes
Michal Rzepecki
Level 3
Level 3
I'm new in AXL, xml, etc. so please forgive me
I can do LDAP synchronization using cURL.
curl -k -u user:pass -H "Content-type: text/xml" -d @request.xml  https://172.17.63.21:8443/axl/
request:
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
    <soapenv:Header/>
    <soapenv:Body>
        <ns:doLdapSync>
        <name>MRlab</name>
        <sync>true</sync>
        </ns:doLdapSync>
    </soapenv:Body>
</soapenv:Envelope>
This is simple but now want to check synchonization status. I tried this
    <soapenv:Header/>
    <soapenv:Body>
        <ns:GetLdapSyncStatusRes>
        <return></return>
        </ns:GetLdapSyncStatusRes>
    </soapenv:Body>
</soapenv:Envelope>
but I'm getting error
<faultcode>axis2ns20:Client</faultcode><faultstring>The endpoint reference (EPR) for the Operation not found is https://172.17.63.21:8443/axl/services/AXLAPIService and the WSA Action = CUCM:DB ver=11.5 GetLdapSyncStatusRes</faultstring><detail /></soapenv:Fault>
actually I don't know how to properly use GetLdapSyncStatusRes. Can someone help me?
You should send Name or uuid property in getLdapSyncStatus(LDAP configuration name)
AXLSoap - getLdapSyncStatus
GetLdapSyncStatusRes - is result of getLdapSyncStatus function
From php I get this info like this
$response = $client->getLdapSyncStatus(array("name" => "MyLDAPname"));
