How to get the configuration of Multiple Call/Call Waiting Settings on sepecific device?
Marcus Luk
In CUCM portal, I can modify the "Multiple Call/Call Waiting Settings" of a specific device by accessing the directory line from that device.
How can I get or even modify these values using AXL? I could not find the entry. Thanks a lot!
npetrele
Check the <line></line> section of addPhone or updatePhone. You'll see
<maxNumCalls>2</maxNumCalls>
<busyTrigger>1</busyTrigger>
Those are the Multiple Call/Call Waiting parameters.
npetrele
