How to get the universal device template "Sample Device Template with TAG usage examples" using AXL
fabien.bonic
Level 5
Level 5
On my CUCM, there is a Universal Device Template named "Sample Device Template with TAG usage examples". I need to retrieve its values using the request getUniversalDeviceTemplate but when I use this request on this particular UDT, I always have the fault "Item not valid: The specified UniversalDeviceTemplate was not found".
I have tried using the name or the UUID with the same result...
When I do the same request on another UDT, there is no problem...
Why do I have this AXL Error despite that the UDT exists?
Fabien
The request:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.0">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getUniversalDeviceTemplate sequence="?">
         <uuid>Sample Device Template with TAG usage examples</uuid>
      </ns:getUniversalDeviceTemplate>
   </soapenv:Body>
</soapenv:Envelope>
The response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Server</faultcode>
         <faultstring>Item not valid: The specified null was not found</faultstring>
         <detail>
            <axlError>
               <axlcode>5007</axlcode>
               <axlmessage>Item not valid: The specified null was not found</axlmessage>
               <request>getUniversalDeviceTemplate</request>
            </axlError>
         </detail>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
The SQL query showing this UDT name:
   <soapenv:Header/>
   <soapenv:Body>
      <ns:executeSQLQuery>
         <sql>select name from device where tkmodel=645</sql>
      </ns:executeSQLQuery>
   </soapenv:Body>
</soapenv:Envelope>
   <soapenv:Body>
      <ns:executeSQLQueryResponse xmlns:ns="http://www.cisco.com/AXL/API/10.0">
         <return>
            <row>
               <name>Sample Device Template with TAG usage examples</name>
            </row>
            <row>
               <name>Auto-registration Template</name>
            </row>
            <row>
               <name>universalDevTemp</name>
            </row>
            <row>
               <name>testGeake</name>
            </row>
            <row>
               <name>testGeake2</name>
            </row>
         </return>
      </ns:executeSQLQueryResponse>
   </soapenv:Body>
</soapenv:Envelope>
dstaudt
Not sure why that template is not accessible, perhaps as it is intended as a 'sample' the implementation filters it out of results.  You should be able to retrieve the details via SQL and <executeSqlQuery>, e.g.:
select * from device where name = "Sample Device Template with TAG usage examples"
charlie.munro
There's always a chance with AXL APIs that the error is not about the object you're requesting. Notice the error message:
It's not saying the UDT wasn't found. It does really say what was found at all.
Follow David's suggestion above and see if there's a NULL in a foreign key (fk) value on the sample that's not null in other templates. Or turn on detailed/debug trace for AXL and see if that tells you exactly what is missing.
fabien.bonic
Level 5
Level 5
After a "save" on the CUCM, the request works. It seems that requests using AXL can put components in an unstable state...
Didn't notice before but you used this:
and that's the name value, not the UUID for the template. Maybe second time you used the <name> tag?
Good luck.
Charlie
