Jabber SDK recoding video with Mediasense Problem
I try to recording the video conversation between the Jabber SDK via CUBE forking solution.
Unfortunately it not working, Video File cut off at 5:30 min and get the bad quality when play back.
Note : Video call is working fine and good quality
Can someone suggest me the solution to recording the video between Jabber SDK.
Best Regards
Boonpot
smupadhy
Can you elaborate on what was tried - the configuration, complete call scenario, etc?
nitinsi
This issue relates to MediaSense when Jabber endpoints are used to make Video calls. Here MediaSense cut shorts the video at 5 min 30 sec because of lack of I-Frames generated by Jabber in the media stream as part of existing design.
All Cisco devices that were used till now used to periodically send I-Frames which MediaSense is currently expecting which broke the functionality since Jabber does not send any I-Frames usually after few initial I-Frames at the beginning of the call.
Following defect was raised to fix the issue and an official ES on 10.5 Release will be available on May 8 as per plan.
CSCut59398 (MediaSense recording cuts off video recording when using Jabber).
Nitin Singh
Hi Nitin,
Thanks for the helpful answer.
I will try and move this forum post to the Recordings (Mediasense) community space, as this information will be helpful to the developers there.
