JAXBElement<XFkType> - Java development
schmetzgilles
Community Member
I'm develop an Web Application to build IPTEL site on Cisco Call Mangager in Java.
I've a little problem, and yes, I've already search and try solutions by myself
So, I'm using the Cisco AXL api 9, and when I want to create an device pool, I need to set the devices pool's property called "LocationName".
The "setLocationName" method requires  'JAXBElement<XFkType> value' that I built before.
The problem is that when I check on my CallManager, nothing is set!
I can set the parameters with XFkType, String, Integer,... but really can't with an JAXBElement<>.
Could you give me an example? A Solution? I can make some test all day long.. I'm developping in NetBeans 7.4. Java. jdk 1.7.
Here is a piece of code to show you the way I try to set my device pool:
// Device Pool
        myDevicePool.setName("DP-" + cc + "-" + sn + "-" + sc);
        //Vérifier l'existance du TZG sinon créer pour le pays.
        XFkType dateTimeGroup = new XFkType();
        dateTimeGroup.setValue("TZG-BEL");
        XFkType CMGroupName = new XFkType();
        CMGroupName.setValue("Default");
        XFkType regionName = new XFkType();
        regionName.setValue(myRegion.getName());
        XFkType mrListName = new XFkType();
        mrListName.setValue(myMrgl.getName());
        JAXBElement<XFkType> mrlName = new JAXBElement(new QName(XFkType.class.getSimpleName()), XFkType.class, mrListName);
        mrlName.setValue(mrListName);
        XFkType locationName = new XFkType();
        locationName.setValue(myLocation.getName());
        JAXBElement<XFkType> jaxLocationName = new JAXBElement(new QName(XFkType.class.getSimpleName()), XFkType.class, locationName);
        jaxLocationName.setValue(locationName);
        //String networkLocale = getCountry();
        //JAXBElement<String> netLocal = new JAXBElement(new QName(String.class.getSimpleName()), String.class, networkLocale);
        //netLocal.setValue(networkLocale);
        if(Gateway)
            if(nameSrst.isEmpty() || nameSrst.equals("NONE"))
            } else {
                XFkType SrstName = new XFkType();
                SrstName.setValue(mySrst.getName());
                myDevicePool.setSrstName(SrstName);
        myDevicePool.setDateTimeSettingName(dateTimeGroup);
        myDevicePool.setCallManagerGroupName(CMGroupName);
        myDevicePool.setRegionName(regionName);
        myDevicePool.setMediaResourceListName(mrlName);
        try {
            myDevicePool.setLocationName(jaxLocationName);
        } catch (Exception e) {
            System.out.println(""+e.getMessage());
            e.printStackTrace();
        //myDevicePool.setNetworkLocale(netLocal);
Thank you for your help,
Gilles.
PS: Please don't hesitate to ask for more information. And don't pay attention to my English, that's clearly not my native language
Geevarghese Cheria
Hi Gilles,
I would request you to refer the following url - https://developer.cisco.com/site/collaboration/management/axl/learn/how-to/axl-java-sample-application.gsp for related information.
Thanks and Regards,
Geevarghese
Frantisek Marousek
Frequent Visitor
Frequent Visitor
Hello, I was solving the same problem and there is my finding (and solution):
My example - I needed to change ownerUserID at device:
Java code at the beginning:
UpdatePhoneReq phReq = new UpdatePhoneReq();
phReq.setUuid(device_uuid);
XFkType user = new XFkType();
user.setUuid(getUserUUID(username));  //returns UserUUID
JAXBElement<XFkType> user2 = new JAXBElement(new QName(XFkType.class.getSimpleName()), XFkType.class, user);
phReq.setOwnerUserName(user2);
Final AXL message (downloaded as AXL log through RTMT):
<?xml version="1.0" ?> <S:Envelope xmlns:S="http://schemas.xmlsoap.org/soap/envelope/"> <S:Body>
<ns2:updatePhone xmlns:ns2="http://www.cisco.com/AXL/API/9.1">
<uuid>63af67a5-9d17-b0b7-7f67-8c4367ad5fd6</uuid>
<XFkType uuid="4d906690-51e4-0c0e-4d6d-70c28599a28c"/>
</ns2:updatePhone></S:Body> </S:Envelope>
- there is no mention about what I want to change (looking into java class UpdatePhoneReq, there is an AXL example at the beginning and I've found that I need to set-up ownerUserName property)
When I've added into my java code:
user.setValue(username);
AXL message contained:
<XFkType uuid="4d906690-51e4-0c0e-4d6d-70c28599a28c">test01</XFkType>
- so still the same
Solution is in:
new JAXBElement(new QName("ownerUserName"), XFkType.class, user)
<ownerUserName>test01</ownerUserName>
and this is working.
You can use it with UUID (probably without Value property):
<ownerUserName uuid="4d906690-51e4-0c0e-4d6d-70c28599a28c"/>
That is all
Good luck
Frantisek Marousek
CCIE Voice #42260
