Step by Step guide for AxlSqlToolkit using by UCCX
Maic Naatz
I would like to use the AxlSqlToolkit for an SQL-Request from UCCX to CUCM. I read some articles, but stuck on multiple things (i.e java classpath, create jar-file (i created somone, but with no luck), use the toolkit with eclipse, create the nessessary set-steps within UCCX, fully qualified names are also an problem for me, and so on). I am not a java developer, so i have no expieriences with eclipse an java himself.
Maybe, there are some guys, who can provide an step-by-step guide, so i can beginn with the basics.
I am an Windows 7 user. My first success: I can run the AxlSqlToolkit with my SQL-Request successfully in a DOS-box. I installed java jdk 1.60_37. The UCCX is version 8.5.1.11002-22. Eclipse Platform is 4.3.2.M20140221-1700.
Hopefully is forgot no details.
Geevarghese Cheria
  I think Cisco UCCX create CTI Route Points/Ports via AXL interfaces. I was able to find this link which is how to perform Steps to integrate AXL SQL Toolkit with CUCM | Contact Center | Cisco Support Community | 5926 | 11538441
Please refer Re: AXL+programming : Why and for what are you using in UC enviroment for related information.
Thanks and Regards,
Geevarghese
