PHP Soap Help
James.Crowley1
Community Member
I am pretty new to using the soap api, so bare with me. I have been able to send a request to cisco call manger and get a response. I asked for the phone info and got it back. But know what I want to do is to change the I want to edit the directory number information, specifically the calling search space. But I do not know the calls I need to call for the api. Is there documentation on the api that list all the commands and calls?
npetrele
You can find all the AXL documentation here:  Cisco AXL
I also recommend the PHP/AXL tutorials here:  Cisco DevNet and here: Cisco DevNet
It helps me to list the AXL functions and AXL types in PHP this way:
echo "<H1>Functions</H1><BR><BR>";
echo "<pre>";
var_dump($client->__getFunctions());
echo "</pre>";
echo "<BR><HR><BR>";
echo "<H1>Types</H1><BR><BR>";
echo "<pre>";
var_dump($client->__getTypes());
echo "</pre>";
KRUNAL LATHIYA
Community Member
Right now to all the people who want to use SOAP, please don't use SOAP.
JSON is the best data type nowadays to work with.
If you want to send an AJAX request then use the JSON Data to exchange the information. It is safe and all the programming language has the full support of that.
Every programming language like Golang, Python, JavaScript, PHP, and Java has inbuilt support of the language.
dstaudt
This sample demonstrates using AXL and PHP, and includes example of adding/updating objects: https://github.com/ciscodevnet/axl-php-samples
