Reporting on Hardware status using AXL
Hi there,
On the RTMT there is a pre-configure alert called HardwareFailure. The description of this alert states:
"This alert occurs when the HardwareFailure event is generated. This indicates that hardware failure event (disk drive failures, power supply failures,...) has occurred."
Is there a way to check using one of the AXL interface on CUCM on that hardware status (same as the pre-configure alarm) that the CUCM VM is sitting on top to check that there is no alerts? I had a look around the RISService interface but only found CPU Memory etc..
thanks
alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
0 Replies 0
