resetHuntList - HTTP 500 when using 10.5 syntax on 11.5 system
stephan.steiner
I forgot to set one of my applications to use 11.5 syntax when testing this afternoon, and ran into this.
The request
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5"><soapenv:Header/><soapenv:Body><ns:resetHuntList sequence="0"> <name>HL_team_guitest</name></ns:resetHuntList></soapenv:Body></soapenv:Envelope>
The AXL debug log then only show
2016-07-22 15:10:38,601 DEBUG [http-bio-443-exec-7] servletRouters.AXLAlpha - ResponseWrapper data size: 268
2016-07-22 15:10:38,621 INFO  [http-bio-443-exec-7] filters.TimingFilter - Request 1469022270992 received from sdkuser at ip 10.80.0.132 was processed in 101ms
And the client gets an HTTP 500 error.
Swap out the 10.5 with 11.5, and things are fine.
While the dev guide for 11.5 isn't out yet, 11.5 should support 10.5 syntax, right?
6 Replies 6
dstaudt
I was able to use a <resetHuntList> request built for and successfully tested against 10.5, and then run it immediately pointing to my 11.5 CUCM.
Is it possible your request has a mismatch of the namespace (10.5) and SOAPAction HTTP header (11.5), or vice versa..?  Can you provide the full HTTP request, including all headers?
Here's the fiddler trace of my request
POST https://chdevcucm105.nxodev.intra/axl/ HTTP/1.1
Authorization: Basic c2RrdXNlcjpzZGt1c2Vy
SOAPAction: CUCM:DB ver=10.5 resetHuntList
Content-Type: text/xml
Host: chdevcucm105.nxodev.intra
Content-Length: 268
Expect: 100-continue
Connection: Keep-Alive
As you can see, namespace in the soap message and the SoapAction are consistent.
And the server response is
HTTP/1.1 500 Internal Server Error
Set-Cookie: JSESSIONIDSSO=665AA6F76CD646154F992F032D347D5A; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=AC9E9593877A4C2FA4C82FC29E92F03B; Path=/axl/; Secure; HttpOnly
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=31536000; includeSubdomains
Content-Type: text/xml;charset=ISO-8859-1
Date: Tue, 04 Oct 2016 15:10:17 GMT
Connection: close
Server:
Content-Length: 268
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><soap:Fault><faultcode>soap:Server</faultcode><faultstring>Couldn't parse stream.</faultstring></soap:Fault></soap:Body></soap:Envelope>
<!--This API has been processed by GAXL not AXL-->
If I change it back to 11.5, the request is
Content-Length: 268
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5"><soapenv:Header/><soapenv:Body><ns:resetHuntList sequence="0"> <name>HL_team_guitest</name></ns:resetHuntList></soapenv:Body></soapenv:Envelope>
And the response
HTTP/1.1 200 OK
Set-Cookie: JSESSIONIDSSO=6237B58364AF2C8351105F60D87C1371; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=461C13E8E3D12932250D84A9153748B0; Path=/axl/; Secure; HttpOnly
Transfer-Encoding: chunked
Date: Tue, 04 Oct 2016 15:11:50 GMT
Server:
146
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5"><soapenv:Body><ns:resetHuntListResponse><return>b9d69cd8-f086-ea67-2c0c-cf3e1d21b7a7</return></ns:resetHuntListResponse></soapenv:Body></soapenv:Envelope>
I note that:
- Neither request is going to the appropriate port (8443)
- The 2nd request does not include the SOAPAction header
though I'm not sure if either of those explain what you're seeing...
Well, I've been using the standard HTTPs Port since CUCM 4, and that has always worked. The missing header has me concerned.. undesireable things do happen if you leave it away so I guess I need to check my code. Interestingly enough, things work fine when I target a 10.5 CUCM with 10.5 syntax (and I do send a lot of commands.. I have customer making entire rollouts on 10.5 with my code)
I've added the missing SOAPAction header to my 11.x requests.. but what used to work still works.. and on a 10.5 it doesn't.
Do you have an 11.5 somewhere where you could run that command to see if you're getting the same behavior? Here's the latest failed attempt again:
Content-Length: 268
Spent some time looking at this and just about out of ideas   Something perhaps is not as it appears..
Enclosed is as close as I could get to your failure request using curl (command.sh and request.xml attached).  Running this against a known 11.5.1.10000-6 CUCM:
[SSL overhead ommitted]
> POST /axl/ HTTP/1.1
> Host: ds-ucm115-1.cisco.com
> Authorization: Basic QWRtaW5pc3RyYXRvcjpjaXNjb3BzZHQ=
> User-Agent: curl/7.47.0
> Accept: */*
> Content-Length: 265
< HTTP/1.1 100 Continue
* We are completely uploaded and fine
< HTTP/1.1 200 OK
< Set-Cookie: JSESSIONIDSSO=F7102891FF736C1E5DCE3020626B4CB3; Path=/; Secure; HttpOnly
< Set-Cookie: JSESSIONID=731A7DA88CCCE9955F8111BE054D2C48; Path=/axl/; Secure; HttpOnly
< X-Frame-Options: SAMEORIGIN
< Strict-Transport-Security: max-age=31536000; includeSubdomains
< Content-Type: text/xml;charset=ISO-8859-1
< Transfer-Encoding: chunked
< Date: Thu, 27 Oct 2016 21:40:27 GMT
< Server:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><ns2:resetHuntListResponse xmlns:ns2="http://www.cisco.com/AXL/API/10.5"><return>f575c929-051b-c7dc-1ccc-8d8da3d4714e</return></ns2:resetHuntListResponse></soap:Body></soap:Envelope>
* Connection #0 to host ds-ucm115-1.cisco.com left intact
If this still fails for you, can you attach a Fiddler output log?
