01-06-2022 03:24 PM
CUCM version 14.0
SoapUI version 5.6.1
UserID = PythonU, it has Super User access control roles
I am building an app to do a global SNMP community string change across our enterprise, 71 clusters. I am receiving Permission Denied errors in my code, so I went to SoapUI to do some basic testing.
There is a community string on my target test CUCM, CPC_PRIME.
The SOAP request in SoapUI is:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/14.0">
<soapenv:Header/>
<soapenv:Body>
<ns:getSNMPCommunityString>
<communityName>CPC_PRIME</communityName>
</ns:getSNMPCommunityString>
</soapenv:Body>
</soapenv:Envelope>
The return from that request is:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server</faultcode>
<faultstring/>
<detail>
<axlError>
<axlcode>-1</axlcode>
<axlmessage/>
<request>getSNMPCommunityString</request>
</axlError>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
I did an RTMT dump and have attached the axl log file. Beginning at line 7231 is where my request begins process. The error seems to be: java.io.FileNotFoundException: /usr/local/Snmpri/conf/snmpd.cnf (Permission denied)
This seems to be to be a very simple request to test with, yet it fails. I am at a loss.
Thanks for any help.
01-07-2022 12:23 PM
I was able to reproduce this problem on my v14 lab setup and opened a defect for tracking: CSCwa60166
It appears that SNMP configuration is handled by directly reading/writing to the OS (vs. the AXL-accessible database), so I don't have much in the way of workarounds to suggest, unfortunately.
It seems possible to use the SSH CLI to query for the existence of a known community string and add new ones - perhaps you could do something with Paramiko to automate; however that kind of 'scraping' solution is not going to be an officially supported API/interface so use at own risk...
01-20-2022 02:23 PM
Looks like CSCwa60166 is a duplicate of CSCvy78363 "axl 14.0 getSNMPUser returning Permission denied", which is marked verified fixed in CUCM version 14.0(1.11900.101).
I believe this should be picked up in the next v14 SR version. The customer can work with Cisco support/TAC to confirm the expected release and/or request an 'engineering special' interim release with the fix.
