SOAP Problem
alexandersatria_Zlf
Frequent Visitor
Frequent Visitor
Hi Guys i was trying a axl codes. but i got problem at SOAP.
I use CUCM 9.1 and my user and password  are operator.
here's my codes
package axl;
import java.io.*;
import java.net.*;
import javax.net.ssl.*;
import java.security.cert.CertificateException;
import java.security.cert.X509Certificate;
public class asd {
  public static void main(String[] args) {
  byte[] bArray = null; // buffer for reading response from
  Socket socket = null; // socket to AXL server
  OutputStream out = null; // output stream to server
  InputStream in = null; // input stream from server
  String sAXLSOAPRequest = "";
  // HTTPS header and SOAP payload
  String sAXLRequest = null; // will hold only the SOAP payload
  String authorization = "operator" + ":" + "operator";
  authorization = new sun.misc.BASE64Encoder().encode(authorization.getBytes());
  // Form the http header
  sAXLSOAPRequest = "POST /axl/ HTTP/1.0\r\n";
  sAXLSOAPRequest += "Host:192.168.10.11:8443\r\n";
  sAXLSOAPRequest += "Authorization: Basic " + authorization + "\r\n";
  sAXLSOAPRequest += "Accept: text/*\r\n";
  sAXLSOAPRequest += "Content-type: text/xml\r\n";
  sAXLSOAPRequest += "SOAPAction: \"CUCM:DB ver=9.1\"\r\n";
  sAXLSOAPRequest += "Content-length: ";
  // Build the SOAP payload
  sAXLRequest = "<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\" ";
  sAXLRequest += "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">";
  sAXLRequest += "<SOAP-ENV:Body> <axl:getPhone xmlns:axl=\"http://www.cisco.com/AXL/1.0\" ";
  sAXLRequest += " xsi:schemaLocation=\"http://www.cisco.com/AXL/1.0 http://axl/schema/AXLSoap.xsd\" ";
  sAXLRequest += "sequence=\"1234\"> <phoneName>SEP000000000001</phoneName>";
  sAXLRequest += "</axl:getPhone> </SOAP-ENV:Body> </SOAP-ENV:Envelope>";
  // finish the HTTPS Header
  sAXLSOAPRequest += sAXLRequest.length();
  sAXLSOAPRequest += "\r\n\r\n";
  // now add the SOAP payload to the HTTPS header, which completes the AXL
  // SOAP request
  sAXLSOAPRequest += sAXLRequest;
  try {
  asd axl = new asd();
  // Implement the certificate-related stuffs required for sending request via https
  X509TrustManager xtm = axl.new MyTrustManager();
  TrustManager[] mytm = { xtm };
  SSLContext ctx = SSLContext.getInstance("SSL");
  ctx.init(null, mytm, null);
  SSLSocketFactory sslFact = (SSLSocketFactory) ctx.getSocketFactory();
  socket = (SSLSocket) sslFact.createSocket("192.168.10.11", Integer.parseInt("8443"));
  in = socket.getInputStream();
  // send the request to the server
  // read the response from the server
  StringBuffer sb = new StringBuffer(2048);
  bArray = new byte[2048];
  int ch = 0;
  int sum = 0;
  out = socket.getOutputStream();
  out.write(sAXLSOAPRequest.getBytes());
  while ((ch = in.read(bArray)) != -1) {
  sum += ch;
  sb.append(new String(bArray, 0, ch));
  socket.close();
  // output the response to the standard output
  System.out.println(sb.toString());
  } catch (UnknownHostException e) {
  System.err.println("Error connecting to host: " + e.getMessage());
  return;
  } catch (IOException ioe) {
  System.err.println("Error sending/receiving from server: " + ioe.getMessage());
  // close the socket
  } catch (Exception ea) {
  System.err.println("Unknown exception " + ea.getMessage());
  return;
  finally{
  try {
  if (socket != null)
  socket.close();
  } catch (Exception exc) {
  exc.printStackTrace();
  System.err.println("Error closing connection to server: "+ exc.getMessage());
  public class MyTrustManager implements X509TrustManager {
  MyTrustManager() {
  // create/load keystore
  public void checkClientTrusted(X509Certificate chain[], String authType)
  throws CertificateException {
  public void checkServerTrusted(X509Certificate chain[], String authType)
  public X509Certificate[] getAcceptedIssuers() {
  return null;
and this is my error
HTTP/1.1 200 OK
Set-Cookie: JSESSIONIDSSO=D2F8AE81113632D88A0B602FAE6412F6; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=AFB227E5DB040C4B262C4817A11F7BC3; Path=/axl/; Secure; HttpOnly
Content-Length: 335
Date: Mon, 07 Sep 2015 03:29:28 GMT
Connection: close
Server:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>VersionMismatch</faultcode><faultstring>There is a mismatch between the namespace specified in the envelope and namespace expected</faultstring></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Below is the raw request generated by the soapUI tool, based on the 9.1 WSDL (I executed it against a v10.5 CUCM, which worked).  The placement and URI of the AXL namespace is different from what you have above, also note that the <phoneName> element should <name> - your XML may be from a previous AXL version..?
POST https://ds-ucm105.cisco.com:8443/axl/ HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: text/xml;charset=UTF-8
SOAPAction: "CUCM:DB ver=9.1 getPhone"
Content-Length: 272
Host: ds-ucm105.cisco.com:8443
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
Authorization: Basic QWRtaW5pc3RyYXRvcjpjaXNjb3BzZHQ=
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getPhone>
         <name>CSFDSTAUDT</name>
      </ns:getPhone>
   </soapenv:Body>
</soapenv:Envelope>
8 Replies 8
npetrele
This part looks incorrect:  xmlns:axl=\"http://www.cisco.com/AXL/1.0\"
Try something like this:  xmlns:axl=\"http://www.cisco.com/AXL/API/9.0\"
i tried xmlns:axl=\"http://www.cisco.com/AXL/API/9.0\" but it's stil showing error
HTTP/1.1 200 OK
Set-Cookie: JSESSIONIDSSO=ACEB1D999CE7DAD65B07E4734A6F0ABC; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=C265282A59E628279346479717AC44C2; Path=/axl/; Secure; HttpOnly
Content-Length: 335
Date: Mon, 14 Sep 2015 04:11:41 GMT
Connection: close
Server:
Can you post the exact XML request?  You don't need to post any of the Java code, just the XML you are sending.
These are my xml codes
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema-instance">
<SOAP-ENV:Body> <axl:GetPhoneRes.java xmlns:axl="http://www.cisco.com/AXL/9.0 xsi:SchemaLocation=\"http://www.cisco.com/AXL/9.0 http://192.168.10.11/Schema/AXLSoap.xsd sequence="4321"> <phoneName>SEP000000000001</phoneName>";
</axl:GetPhoneRes.java> </SOAP-ENV:Body> </SOAP-ENV:Envelope>";
The version in the namespace needs to match the version submitted in the 'SOAPAction:' header - looking at the above you have '9.0' vs. '9.1'...
Hi dstaudt
actually i am still not understand why i got error <faultcode>VersionMismatch</faultcode>
i think my code must be work .
i tried   9.0 and 9.1
but it'still same and got this error
Connection: close
Server:
     <SOAP-ENV:Header/>
               </SOAP-ENV:Body>
here's my codes
  sAXLRequest += "<SOAP-ENV:Body> <axl:getPhone xmlns:axl=\"http://www.cisco.com/AXL/9.1\" ";
  sAXLRequest += " xsi:schemaLocation=\"http://www.cisco.com/AXL/9.1 http://axl/schema/AXLSoap.xsd\" ";
notes
#my cucm is cucm 9.1
Content-Length: 272
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getPhone>
      </ns:getPhone>
   </soapenv:Body>
</soapenv:Envelope>
Ty dstaudt
it's finally success.
