SOAP update to device profile speed dials in CUCM
Bhunt 410
Does anyone have an example they can share to update the speed dials of a device profile, or any device really in this format?
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.0">
  <soapenv:Header/>
  <soapenv:Body>
   <ns:updateLine sequence="?">
    <pattern>"dn"</pattern>
    <routePartitionName>'''internal'''</routePartitionName>
    <newRoutePartitionName>"test"</newRoutePartitionName>
   </ns:updateLine>
  </soapenv:Body>
</soapenv:Envelope>'''
I have had success using this method with curl to change directory number partitions, this is an example I found online a while back.
BAT has an update speed dials based on template for phones, but not device profiles. I know you can use bulk import / export, but I have had bad experiences with that in the past and an looking to learn more about using the SOAP API.
It is ok if I need to first query the pkid for the device profiles, I can query them from the CLI in advance.
npetrele
Here is an example of how you'd set speed dials on a device profile:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:updateDeviceProfile>
         <name>Test Device Profile</name>
         <speeddials>
            <speeddial>
               <dirn>7926</dirn>
               <label>Nick Fury</label>
               <index>1</index>
            </speeddial>
            <speeddial>
               <dirn>7101</dirn>
               <label>Nick Danger</label>
               <index>2</index>
            </speeddial>
         </speeddials>
      </ns:updateDeviceProfile>
   </soapenv:Body>
</soapenv:Envelope>
amoherek
I'm moving this post to the AXL forums so that those subscribed to that space can reply.
npetrele
   <soapenv:Header/>
   <soapenv:Body>
         <speeddials>
            <speeddial>
               <dirn>7926</dirn>
               <index>1</index>
            </speeddial>
            <speeddial>
               <dirn>7101</dirn>
               <index>2</index>
            </speeddial>
         </speeddials>
   </soapenv:Body>
</soapenv:Envelope>
Thank you so much, we have a working script.
