updateCredentialPolicyDefault AXL problem
peteryun
From UI, both boxes can be false, unchecked but via AXL is failing.  Any suggestions?
2018-03-19 14:30:48,789 ucapi.cucmapi.CUCMAPI :78 - _send() - DEBUG send POST https://h1002autosjccm001.pg.net:8443/axl/
  Connection: keep-alive
  Accept-Encoding: gzip, deflate
  Accept: */*
  User-Agent: python-requests/2.18.4
  SOAPAction: CUCM:DB ver=11.5 updateCredentialPolicyDefault
  Content-Type: text/html;charset=UTF-8
  Content-Length: 478
  Authorization: Basic YWRtaW46QyFzY29fMTIz
  Body:
<?xml version="1.0" ?>
<soapenv:Envelope xmlns:ns="http://www.cisco.com/AXL/API/11.5" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
    <soapenv:Header/>
    <soapenv:Body>
        <ns:updateCredentialPolicyDefault>
            <credUserMustChange>false</credUserMustChange>
            <credUserCantChange>0</credUserCantChange>
            <credentialUser>End User</credentialUser>
            <credentialType>PIN</credentialType>
            <credPolicyName>FedRAMP Credential Policy</credPolicyName>
        </ns:updateCredentialPolicyDefault>
    </soapenv:Body>
</soapenv:Envelope>
2018-03-19 14:30:48,790 urllib3.connectionpool :824 - _new_conn() - DEBUG Starting new HTTPS connection (1): h1002autosjccm001.pg.net
2018-03-19 14:30:49,351 urllib3.connectionpool :396 - _make_request() - DEBUG https://h1002autosjccm001.pg.net:8443 "POST /axl/ HTTP/1.1" 500 515
2018-03-19 14:30:49,353 ucapi.cucmapi.CUCMAPI :81 - _send() - DEBUG receive 500 Internal Server Error
  Set-Cookie: JSESSIONIDSSO=B99E2A598AE583FFB06670CAA39FDA31; Path=/; Secure; HttpOnly, JSESSIONID=5364DB4F8A4AE95899687762D79B4603; Path=/axl; Secure; HttpOnly
  X-Frame-Options: SAMEORIGIN
  Strict-Transport-Security: max-age=31536000; includeSubdomains
  Content-Type: text/xml;charset=UTF-8
  Content-Length: 515
  Date: Mon, 19 Mar 2018 14:34:02 GMT
  Connection: close
  Server:
  Body:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
    <soapenv:Body>
        <soapenv:Fault>
            <faultcode>soapenv:Server</faultcode>
            <faultstring>credUserCantChange and credUserMustChange both can not be same</faultstring>
            <detail>
                <axlError>
                    <axlcode>5003</axlcode>
                    <axlmessage>credUserCantChange and credUserMustChange both can not be same</axlmessage>
                    <request>updateCredentialPolicyDefault</request>
                </axlError>
            </detail>
        </soapenv:Fault>
    </soapenv:Body>
</soapenv:Envelope>
dstaudt
This seems like it may be a defect - I'm able to reproduce the issue and don't see any reason why it should fail.  I've opened defect CSCvi56136 for tracking.
Unfortunately, attempting to update the default credential policy via <executeSqlUpdate> fails with a permission error, so it appears that will not be available as a workaround...
Thanks!
