updateLocation question
Martin Sloan
Level 2
Level 2
I'm trying to disassociate Call Manager locations via AXL updateLocation but can't seem to get it working.  I've tried sending updateLocation with:
- No 'betweenLocations' element
- Empty 'betweenLocations' element
- No 'betweenLocation' element
- Empty 'betweenLocation' element
Afterward, the location association and bandwidth settings from the locationmatrix table remain.  Is it possible to remove the location mapping via updateLocation?
TDoan
Level 3
Level 3
Hi Martin,
Please try this one
<ns:updateLocation sequence="1">
           <name>Phantom</name>
           <betweenLocations>    //You need to check this
                 <betweenLocation>
                      <locationName>
                              <uuid>{C7E2C026-54B3-55DD-A0A2-D649501F9929}</uuid>  //uuid of Phantom
                      </locationName>
                      <weight> Your value </weight>
                      <audioBandwidth> Your value </audioBandwidth>
                      <videoBandwidth> Your value </videoBandwidth>
                      <immersiveBandwidth> Your value </immersiveBandwidth>
               </betweenLocation>
           </betweenLocations>
           </ns:updateLocation>
Hope this would help you.
Thuy Doan
Thuy,
Thank you for the assistance.  I've done a little more troubleshooting and have discovered a little 'quirk' in this API.
We're preparing to move our clusters to a 'Location and Link Management Cluster' Inter-Cluster ELCAC design with SME and need to update a few hundred location relationships, mainly with Hub_None.  What I've discovered is that when using the API and passing in the empty <betweenLocations/> tag, it only produces updates based on a 'forward' lookup of the locationmatrix table.  For instance:
Given location123 and location789 in the locationmatrix table as fklocation_a = location123 and fklocation_b = location789, if I call updateLocation on location789 with an empty <betweenLocations/> tag, the relationship will persist because the API updates the relationship only from location_a to location_b ('forward') and not in 'reverse'.  So, the locations I was trying to update were most likely assigned from the Hub_None page, with Hub_None as fklocation_a and so the update were not applied.
FWIW, here's the API call that does work when making an update in the 'forward' direction.
<ns1:updateLocation>
  <name>location123</name>
  <withinAudioBandwidth>0</withinAudioBandwidth>
  <withinVideoBandwidth>0</withinVideoBandwidth>
  <withinImmersiveKbits>0</withinImmersiveKbits>
  <betweenLocations/>
</ns1:updateLocation>
I wonder if this was intentional or a glitch, since you can update the relationship from either side in the GUI?
Marty
