UpdatePhoneReq ?
mikael.pouponnot
Community Member
I want to use "UpdatePhoneReq" in a Java project to modify the "moh network value" of a phone.
Is anyone can give me an example ?
UpdatePhoneReq UpdatePhoneReq = new UpdatePhoneReq();
npetrele
What problems are you having using the method setNetworkHoldMohAudioSourceId?
hi nicholas,
Thanks, but I found a way to use the setNetworkHoldMohAudioSourceId method. Could you please help me to use the ListMohAudioSourceRes method, i try to return a list of all the moh sources included in my CUCM.
