Updating a phone with Python
mike.wilcox
Visitor
SOLVED via Google. 🙂
I am using python and suds-jerko to update the line label on phones. My issue is figuring out the formatting of the line info in updatePhone. using this code:
resp = client.service.updatePhone(name = 'SEPAC44F214C7EB', description = "MJW Test",
lines = { lineIdentifier : {pattern : '83774356', routePartitionName : 'AMR-L1-PT'},
label : "83774356"})
I get this error:
NameError                                 Traceback (most recent call last)
/var/folders/7c/lghfcp0n1x5_kzxyj55__5g00000gn/T/ipykernel_41974/1536426317.py in <module>
      1 resp = client.service.updatePhone(name = 'SEPAC44F214C7EB', description = "MJW Test",
----> 2                                  lines = { lineIdentifier : {pattern : '83774356', routePartitionName : 'AMR-L1-PT'},      3                                            label : "83774356"})
NameError: name 'lineIdentifier' is not defined
Any input on how to format this correctly?
THanks,
Mike
npetrele
Check your curly braces.  The "label" is incorrectly folded into the "lines":
lines = { lineIdentifier : {pattern : '83774356', routePartitionName : 'AMR-L1-PT'}, label : "83774356"}
Should be
lines = { lineIdentifier : {pattern : '83774356', routePartitionName : 'AMR-L1-PT'} } <-need another bracket here,
label : "83774356"}
npetrele
Should be
label : "83774356"}
