XAddPhone violates nillability of confidentialAccessMode
Jonathan Els
Level 5
Level 5
As per the xsd for XPhone, confidentialAccessMode should be nillable:
<xsd:element maxOccurs="1" minOccurs="0" name="confidentialAccess">
    <xsd:complexType>
        <xsd:sequence minOccurs="0">
            <xsd:element maxOccurs="1" minOccurs="1" name="confidentialAccessMode" nillable="true" type="axlapi:XCALMode"/>
            <xsd:element maxOccurs="1" minOccurs="1" name="confidentialAccessLevel" nillable="true" type="axlapi:XInteger"/>
        </xsd:sequence>
    </xsd:complexType>
</xsd:element>
However, this is not honoured by AXL during addPhoneReq.  If the following is sent to CUCM:
<confidentialAccess>
    <confidentialAccessMode xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
    <confidentialAccessLevel>-1</confidentialAccessLevel>
</confidentialAccess>
This results in an error:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
  <soapenv:Body>
    <soapenv:Fault>
      <faultcode>soapenv:Server</faultcode>
      <faultstring>Invalid value for confidentialAccessMode</faultstring>
      <detail>
        <axlError>
          <axlcode>5003</axlcode>
          <axlmessage>Invalid value for confidentialAccessMode</axlmessage>
          <request>addPhone</request>
        </axlError>
      </detail>
    </soapenv:Fault>
  </soapenv:Body>
</soapenv:Envelope>
However, AXL will support fully enclosed tags, which technically should be analogous to the above:
    <confidentialAccessMode></confidentialAccessMode>
This magically works.
I picked this up from trying to work with a getPhone, where the AXL response actually does send a nill response itself:
    <confidentialAccessMode/>
Clearly, this is a bug.
Jonathan Els
Level 5
Level 5
The workaround is to force sending an empty string '' for the attr.
