Using a smartcard for authentication
Sourabh_N
Community Member
I was wondering if Duo supports using a smartcard as the 2nd factor… that is instead of using the Windows built-in smartcard provider, if it was possible to enroll a smartcard with Duo and use it for Windows Login.
DuoKristina
No, we only support Duo MFA instead of smart card and Duo MFA plus smart card. These options are described in step 5 of the install instructions here.
Feel free to contact your account exec, customer success manager, or Duo Support if you’d like to submit a feature request for using smart cards as native Duo MFA authenticators.
Duo, not DUO.
