Managing Devices
Share tips on managing device authentication methods. Stay current on device management and learn from our community!
Hello, We have noticed Duo Desktop takes a long time to load at Windows startup. Assuming this is because it loads in the user (startup) context, which is the lowest priority. If people launch their browsers before Duo Desktop loads, they have issues...
doGlooPA by • Level 3
  • 1351 Views
  • 9 replies
Currently we are testing Duo Passwordless with proximity push for Duo Mobile. Works fantastic. There is a delay of over 20 seconds between when I click "Sign-In" in Windows and when it pings my phone for an approval. Generally takes between 20-22 sec...
  • 906 Views
  • 3 replies
我扫描二维码后成功在手机上获得了6位数的登录验证码,但我删除了账号。现在我再次登录网站时,仍然需要输入这个6位数的验证码,但我不知道该如何重新获取它。请问有人知道该怎么办吗?
admin451 by • Community Member
  • 606 Views
  • 1 replies
 Google will release version 141 on Sept. 30th and this adds a feature to automatically block local LAN access. You can set a flag on your Chrome now to test this. In my testing on multiple PC's, it seems that passport stops auto logging me into Duo ...
  • 1833 Views
  • 2 replies
Hello, I am having and issue with a MacBook pro that I am working on setting up DUO 2FA for. This M3 MacBook is running Seqouia version 15.3.2. I am having a weird issue where I set up Duo on it, but it only works when on wi-fi, but the duo push fail...
eortizz by • Community Member
  • 2668 Views
  • 2 replies
Hi,I have a yubikey in OTP mode that i use as a hardward token.  It is attached to my user account and works fine for Microsoft RDP.I also have a unix login application protected by duo (auto-push disabled). The problem is the only options I am give ...
mikeC2 by • Community Member
  • 1216 Views
  • 2 replies
 Hello, New Duo customer here, just setting things up and figuring them out. We have our AD integration, test groups and Duo Mobile with Duo for Windows logon working great. I was a little confused about how Duo Desktop works and I think I have found...
  • 2510 Views
  • 2 replies
