04-29-2021 12:00 PM
Hello - I’m working on implementing the YubiKey 5 NFC for an organization and I’m wondering how users would authenticate on mobile devices such as their phones and tablets? My scenario will focus on Microsoft Azure Active Directory - so a Duo Prompt would appear after implementation for users that have Outlook on their phones.
I found an old thread here, but nothing else:
Documentation states nothing about mobile devices:
https://guide.duo.com/security-keys
05-05-2021 08:06 AM
Hi @JuniorSA,
Based on what I can find so far, Yubikey 5 NFC will not work on a mobile device with Duo. For tablets and phones, we recommend using Duo Mobile to authenticate instead. Have you already looked into that, and is there a reason you don’t want to use it if so?
05-05-2021 08:23 AM
Hey Amy - thanks for the reply.
A client I’m working with would prefer using the YubiKey as they don’t want to force the installation of the Duo Mobile app on their employee’s phones.
I personally prefer the Duo Mobile app and Duo Push for authentication… but sometimes it isn’t my call ![]()
Thank you!
05-05-2021 10:52 AM
Ah, that makes sense. It is a common thing we hear from users, so I understand. Thank you for sharing that additional info.
The only other option I can think of would be to use a hardware token, or potentially phone call or SMS, but those may not be the best for your given situation as they have their own drawbacks. Sorry I can’t be of more help here!
06-14-2021 07:45 AM
I was able to authenticate by enabling NFC on my Android phone, and putting the Yubikey 5 NFC to the back of the phone. The phone then prompted me to open a Yubico site that gave me access to copy my passcode into the challenge field for the Office authentication.
06-14-2021 08:05 AM
Did you have to do any additional configuration in the Duo Admin Console or to the Yubikey??
06-14-2021 08:09 AM
I followed the instructions listed here to “program” the Yubikey and add it to our console and attach it to the user account.
However, after re-reading your post, we are using a hybrid environment with ADFS, which may make the difference regarding the authentication ability.
06-14-2021 08:29 AM
Yep I did try this with no success with Azure being the protected application. Plus, with over 50 keys being sent to remote clients this seems quite cumbersome!
Thanks for the input!
