Authentication keep live
manvik
Level 7
Level 7
Is it possible for DUO to not ask 2FA for a certain period, like 2 hours from first login.
An user might login multiple times to a device/system. Every time entering a 2FA is difficult.
DuoPablo
Hi @duorunner1 ,
Depending on the application type, its possible to use a Remembered Devices policy to bypass 2FA for a set period of time.
How do Remembered Devices work?
Which applications support Remembered Devices and Authorized Networks?
Hope this helps!
DuoPablo
Hi @duorunner1 ,
Hope this helps!
