Cisco DUO with offline user Authentication
Alan Tang
Hello:
I have an environment that the existing Private AD did not allow to have internet access. These Private AD was in the private segment. It have an Remote Desktop Server Farm that was under the Private AD.
1.) I have export the existing AD Account and import to Cisco DUO Cloud
2.) I have setup a DUO Proxy to have access to internet at DMZ (Cannot access to any AD)
3.) The Remote Desktop Session Host can connect with DUO Proxy with port 443
May I know when the user was connect to the Remote Desktop. Did it will prompt another login account due to no any AD intergation on DUO?
Thanks!
DuoKristina
If the RDS deployment has Duo installed in it, and the Duo application can make the outbound connection to Duo via the proxy, and the RDS deployment also has connectivity to the private AD, then it should be OK?
Private AD user > private RDS > Duo application installed on private RDS > Duo proxy in DMZ > Duo's cloud service
Duo, not DUO.
