Duo Auth Proxy Ldaps for vCenter
Alex H
Do you have any idea on this?
[ldap_server_auto]
client=ad_client
ikey=nnnn
skey=nnnn
api_host=api-nnnn.duosecurity.com
failmode=secure
factors=push
exempt_ou_1=X
exempt_primary_bind=false
After Enable I checked on port seeing certificate is work now. but I tried with same certificate at vCenter is not working to add Ldaps://server:3289
ssl_port=3289
ssl_cert_path=ldap_server.pem
ssl_key_path=ldap_server.key
DuoKristina
Does vCenter reject the cert or does the Duo Authentication Proxy reject the SSL connection?
The key file specified in authproxy.cfg can't be encrypted or password-protected (that's a common issue we see when LDAPS fails).
Duo, not DUO.
Alex H
vCenter has rejected the certificate.
ldap_server.key is only Private Key is it correct?
ldap_server.pem is only Public Key is it correct?
In the authproxy.cfg I didn't encrypt the password.
ldap_server.pem is the issued certificate.
If vCenter rejects the cert, does vCenter trust the cert's issuer?
Duo, not DUO.
Alex H
Not sure it's something wrong with self-signed certificate. but I tried to use third-party certificate is worked fine.
Nevermind I will use the third-party certificate for this.
