Capture IP packets
luanwc
Community Member
which command on GSR 12008 can monitor the Source IP address and port, destination IP address and port etc. I want to use this message to detect some network virus such as worms use bugs of MS SQL-server . thank you.
ivillegas
Level 11
Level 11
Enable Netflow accounting in GSR 12008 will aid in monitoring the Source IP address and port, destination IP address and port.
The following links has the detailed information on Netflow configuration
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/netflsol/nfwhite.htm#xtocid6
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/netflsol/nfenterp.htm#xtocid4
luanwc
Community Member
I have seen these DOCs , but I cann't find some simply command on GSR to view necessary message directly on the telnet window or on console.
