Cisco AnyConnect application
Hong Jin
Dear all,
I could not find Cisco AnyConnect in Iphone App Store any more.
9 Replies 9
Tushar Bangia
Hope you followed below steps:
Installing AnyConnect
Install the Cisco AnyConnect Secure Mobility client for Apple iOS from the Apple App Store, as follows:
Step 1 Open the App Store.
Step 2 Select Search.
Step 3 In the Search Box, enter anyconnect and tap cisco anyconnect in the Suggestions list.
Step 4 Tap AnyConnect.
Step 5 Tap Free, then INSTALL APP.
Step 6 Select Install.
Refer below link for more: information:http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/user/guide/iphone-ugac-ios.html
Hello!
I have the exact same problem. I have searched app store on two different devices. All i could find was; "cisco technical support" and "vpnGuru - express IpSec vpn setup".
Where has it gone? I have downloaded anyconnect several times on different ios devices.
I can still find it in the google play on android thou.
The client gone missing again from app store, anyone know what had happened?
It is gone. Not in the app store any more.
Cisco, please let us know where it went.
The App is NOT on the Apple App store any longer. "App is no longer available in usa" I have many user having the same issue.
Please advise.
bnbaugh35
Since the most recent update, our users are reporting an error when attempting to use the Secure Mobility app...
I suspect the app has been pulled until a fix is available.
An update from Cisco on the status/timeline would be appreciated.
Thanks!
Michael Endler
Is again available, i installed it yesterday.
Thanks~
lizzamark8
Now, the app  is available on Apple App Store. You can install it again
