Acceptable delay through MPLS Backbone
f-cagica
Level 2
Level 2
at between 2 CPE routers there are 4 routers from an MPLS Backbone. The total distance should be around 10000 Km. I need some reference values for the acceptable RTT between the two endpoints. Is there any reference table or Doc. describing it (or, does anyone has some Ref. from the experience)?
Thank you in advance
Fernando
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Perhaps 100 to 120 ms, RTT.  This assuming 5 to 6 microseconds latency per KM (one direction).
PS:
Keep in mind, 10,000 KM networks aren't always a straight line.
Thanks Joseph.
Fernando
