EoMPLS fail
rivalino_ymt
I am setting up EoMPLS (AToM) in my lab. Topology is simple, just have 2 Cat6509 (with native IOS) connect back-to-back. These 2 Catalyst act as PE. On each catalyst, there is one catalyst acting as host (CE). I am configuring 'mpls l2transport' under interface vlan, instead of subinterface. It is weird when i found that under subinterface, there is no command 'mpls l2transport' nor 'xconnect'. Both command is available only under interfce vlan and L3 interface.
You all can check my configuration. Thanks fr every response.
5 Replies 5
Change the netmask of the loopback address on R1 to /32 instead of /24.
Also "mpls ip" doesn't need to be configured on interface vlan23.
Hope this helps,
Hello
Please do the configuration on physical interface except over Vlan
interface GigabitEthernet1/45
mpls l2transport route 1.1.1.1 100
no ip address
end
What is superviser engine on 6500
Could you also attach a "show mpls l2transport vc detail" from R2.
dudko
EoMPLS is not supported on Layer 3 VLAN interfaces for C6500/7600.
If you need to configure EoMPLS on the SVI the core-facing card must be an OSM.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/pfc3mpls.htm#wp1279824
Kind regards,
Dmitriy.
HI Dmitriy
EoMPLS is supported on 6500 and 7609 if you have sup7203b or sup7203bxl cards.
you need OCM base cards for VPLS
well can you attache sh tech file here...
Kind regards
Zeeshan Nadeem
