EVPN interoperability with VPLS
emurray
Level 5
Level 5
I am studying for the CCNP ISPCORE and i am configuring EVPN. I have configured EVPN so far with no problems but can't seem to make it work when one of the sites is using vpls. Many documents and presentations say there is interoperability, but I have not been able to make it work.
PE running IOS XE
 l2vpn vfi context VPLS-EVPN_TEST
 vpn id 3091
 mtu 9180
 autodiscovery bgp signaling bgp
  rd 10.0.0.1:3091
  route-target export 65000:3091
  route-target import 65000:3091
 member vfi VPLS-EVPN_TEST
Site with IOS XR running EVPN
 evpn
 ethernet-segment
 evi 3091
  bgp
   rd 10.0.0.2:3091
  description TEST VPLS EVPN
  advertise-mac
I am able to ping on the sites that run EVPN but no with the one using the VPLS. Any help will be welcomed
sidshas03
So, you’ve done a pretty good job setting up EVPN and VPLS separately, and you’re right – many documents do mention that EVPN and VPLS interoperate, especially in terms of MAC learning and BGP signaling. But practically, when one site is on IOS XE using VPLS and the other on IOS XR with EVPN, some compatibility issues often crop up. This is because EVPN uses Type 2 (MAC/IP Advertisement) and Type 3 (Inclusive Multicast Ethernet Tag) routes, whereas traditional VPLS using BGP doesn't understand these route types properly.
Your IOS XE VPLS config is using BGP for autodiscovery and signaling – that part is correct. But for proper interop with EVPN, especially with IOS XR on the other side, you'll need to enable EVPN signaling on the XE side too, because XR expects EVPN routes, not old-style VPLS ones.
Unfortunately, native interop between EVPN and VPLS works well when both ends support EVPN (with backward compatibility), but mixing classic VPLS with EVPN isn’t always seamless unless you’re using a gateway or doing some form of stitching between the two technologies, like:
  • Interworking with bridge domains where you do local bridging between EVPN and VPLS instances on the same PE (if your platform allows).
  • Or you may need to run both EVPN and VPLS on the same PE with separate bridge domains and stitch them together internally.
So, my suggestion is: if your hardware supports it, try enabling EVPN on the XE side also, or use a dedicated PE as an interop gateway that does EVPN to VPLS stitching. Also, check if the VPLS side is able to learn MACs from EVPN advertisements (use show bgp l2vpn evpn on XR and show l2vpn vfi on XE to debug MAC learning).
Thanks for the answer. I tried to stitch them together in the IOS XR PE, with no luck. It seems the NCS 540 which is the one that I am using for IOX XR, does not support stitching. It lets you configure the stitching but does not support actual data-plane stitching between VFI and EVI members inside the bridge-domain.
probably the 9K or 560 will work but I don't have access to those at the moment to test it out. If anyone can test it and let me know I will thank you.
Also, below is my config in case you see something wrong.
l2vpn
 bridge group TEST
  bridge-domain VPLS_EVPN_2591
   mtu 9180
   interface GigabitEthernet0/0/0/10.2591
   interface GigabitEthernet0/0/0/13.2591
   vfi 2591
    vpn-id 2591
    autodiscovery bgp
     rd 10.0.0.2:2591
     route-target import 65000:2591
     route-target export 65000:2591
     signaling-protocol bgp
   evi 2591
vfi VPLS100
vpn-id 100
neighbor 10.0.0.2 pw-id 100
The interconnect between two router (GW of vxlan) and VPLS need to be static no need bgp autodiscover
MHM
This is an MPLS with no VXLAN. It runs with LDP. It seems that the NCS 540 does not support the signaling required to integrate the VPLS with EVPN. Probably the ASR 9000k does support the integration. But doing a static interconnect with VPLS with a point to point is possible. Keep in mind that EVPN has autodiscovery integrated, so that will not be a integration of VPLS with EVPN
