How to enable MPLS in ATM switch?
teru-lei
Hi All,
I am studying MPLS. And in my book it just said in order to enable MPLS in the ATM switch for running cell mode, use "mpls ip" command in the interface mode is ok. But when I tried it no LS1010, and when I added the command, it said that no control-vci is available on that interface. Can anybody help me? Is the command "ip cef"command needed in ATM switch? I think the command is not needed.
Thank You!
gmarogi
Level 5
Level 5
By default, 0/32 is the VPI/VCI used as the control VC for MPLS. See if this is available and matches between the peers, or use the 'tag-switching atm control-vc' command to set the values manually.
