influencing BGP attributes within MPLS network
Manoj Buddhika
pls take a look at my question and diagram is attached in the file. pls help me to fix this problem.
I have following requirement about traffic paths within the
MPLS network.MPLS network is running MP-BGP4.
1.Traffic from Europe branch to Asia branch go through London
  router.
2.Traffic from America branch to Asia branch go through Los Angeles
  router.
3.The two paths through London and Los Angeles should have redundancy.
  That is if path through London is not accessible all the traffic must
  go through Los Angeles. IF Los Angeles path go down all the traffic must
  go through London.
4.Traffic from Asia to Europe and America is controlled by redistributing
  BGP4 learned routes with different metrics at the London and Los Angeles
  routers.So that trafic from Asia branch to Europe go through London and
  traffic from Asia to America go through Los Angeles.
I have been using below configs on the PE routers. But it is not working.
In the MPLS network only one path is selected for both traffic from Europe
and America.Pls can anyone help me to fix this problem.
#PE3
ip vrf CUSTOMER
rd 1:10
route-target export 1:20
route-target import 1:40
export map EXPORT-ROUTE
import map IMPORT-ROUTE
interface FastEthernet0/0
description LONDON-GW
ip vrf forwarding CUSTOMER
ip address 1.1.1.2 255.255.255.252
router bgp 65400
address-family ipv4 vrf CUSTOMER
redistribute connected
neighbor 1.1.1.1 remote-as 65401
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 next-hop-self
neighbor 1.1.1.1 soft-reconfiguration inbound
no auto-summary
no synchronization
exit-address-family
ip extcommunity-list 1 permit rt 1:10
ip extcommunity-list 2 permit rt 1:40
route-map EXPORT-ROUTE permit 10
match extcommunity 1
set extcomm-list 1 delete
set extcommunity rt 1:20 additive
route-map IMPORT-ROUTE permit 10
description EU & US-BRANCH
match extcommunity 2
#PE4
ip vrf CUSTOMER
rd 1:10
route-target export 1:30
description LA-GW
ip address 2.2.2.2 255.255.255.252
router bgp 65400
neighbor 2.2.2.1 remote-as 65402
neighbor 2.2.2.1 activate
neighbor 2.2.2.1 next-hop-self
neighbor 2.2.2.1 soft-reconfiguration inbound
no auto-summary
no synchronization
exit-address-family
description LA-GW
set extcommunity rt 1:30 additive
#PE1
ip vrf CUSTOMER
rd 1:10
route-target export 1:40
route-target import 1:20
route-target import 1:30
description EU-BRANCH
ip address 3.3.3.2 255.255.255.252
router bgp 65400
redistribute static
no auto-summary
no synchronization
exit-address-family
ip route vrf CUSTOMER 172.16.1.0 255.255.255.0 FastEthernet0/0 3.3.3.1 name EU-BRANCH
ip extcommunity-list 2 permit rt 1:20
ip extcommunity-list 3 permit rt 1:30
set extcommunity rt 1:40 additive
description LONDON-GW(MAIN)
set metric 100
route-map IMPORT-ROUTE permit 20
description LA-GW(BACKUP)
match extcommunity 3
set metric 200
route-map IMPORT-ROUTE permit 30
description OTHER
#PE2
ip vrf CUSTOMER
rd 1:10
description US-BRANCH
ip address 4.4.4.2 255.255.255.252
router bgp 65400
redistribute static
no auto-summary
no synchronization
exit-address-family
ip route vrf CUSTOMER 192.168.1.0 255.255.255.0 FastEthernet0/0 4.4.4.1 name US-BRANCH
description LONDON-GW(BACKUP)
set metric 200
description LA-GW(MAIN)
set metric 100
description OTHER
25 Replies 25
Hi Varma,
I still find some difficulties when configuring. I dont know whether it is IOS version problem or anything else.
Here is a example I found when configuring on PE3
your suggest command -> ip extcommunity-list standard CUSTOMER permit rt 1:20
but in my router I only have this ->ip extcommunity-list 77 permit rt 1:20
I cant have a text like "CUSTOMER" for extcommunity lis name. But I think that is OK ,I still could configure the community list.
the next problem is more anoying.
     route-map community permit 10
     match extcommunity CUSTOMER
     set community 65400:1111
   I could configure that except for the "CUSTOMER" I used "77" which is my standard community list number. but on the show running
   config it will appear as this.
!route-map community permit 10
!match extcommunity 77
!set community -8911785
the  65400:1111  will change to a minus number
I wonder why is that ? could you please give some advice on that
Thank you
Manoj
Hi Manoj
Please use the below command to enable the new community format on your IOS
"ip bgp-community new-format"
Varma
Hi Varma,
Thanky you very much for your helping.
after  ip bgp-community new-format
I could overcome that problem.
bug still have these problems as mention below
#PE1
I couldn't configure this command "ip community list CUSTOMER permit 65400:1111
that is I cant use 65400:1111 format after permit. I can only use rt AS:nn format.
so I configured like this
ip community-list  77 permit rt 1:20
here 77 is for CUSTOMER which is your standard-list name. I think it is ok. problem is instead of 65400:1111
i used rt1:20 because 65400:1111 is inported as rt 1:20
#PE2
same as PE1 couldn't  configure your command ip community list CUSTOMER permit 65400:2222.
instead I used this
ip community-list 77 permit rt 1:30
that is because 65400:2222 on PE4 is imported as rt 1:30 on PE2
after configuring as above ,still all the traffic from europe and america will select only one path  that is throuth PE3
please if you have any thoughts where I might wrong , I would be very much appricated.
thank you for your valuble time
Best regards
Manoj
Hi Manoj
Can you please share your modified configs of all the 4 PEs with changes highlighted..
RT is an extcommunity and we should be able to permit it under standard community . Have you configured this command ?
Varma
Hi Varma
This is my new configs on all the four PE routers and two route-reflectors.
waiting for any ideas from you, where I might I have configured it wrong.
thanks.
#PE3
ip vrf CUSTOMER
rd 1:10
address-family vpnv4
neighbor PEER-GROUP send-community both
neighbor PEER-GROUP route-map community out
neighbor RR1-IP activate
neighbor RR2-IP activate
exit-address-family
no auto-summary
no synchronization
exit-address-family
route-map community permit 20
#PE4
ip vrf CUSTOMER
rd 1:10
exit-address-family
no auto-summary
no synchronization
exit-address-family
ip extcommunity-list 77 permit rt 1:30
set community 65400:2222
#PE1
ip vrf CUSTOMER
rd 1:10
neighbor PEER-GROUP route-map community in
exit-address-family
redistribute static
no auto-summary
no synchronization
exit-address-family
set local-preference 110
#PE2
ip vrf CUSTOMER
rd 1:10
exit-address-family
redistribute static
no auto-summary
no synchronization
exit-address-family
RR1  route-reflector1
neighbor PEER-GROUP route-reflector-client
neighbor PE3-IP activate
neighbor PE4-IP activate
neighbor PE1-IP activate
neighbor PE2-IP activate
RR2 route-reflector2
Hi, Varma
Here I put the how the paths are selected by PE1,PE2 for the network  10.0.2.0/24 .
As you can see both PE1,PE2 select PE3 as the next-hop.
PE1#
PE1#show ip bgp vpnv4 vrf CUSTOMER
Load for five secs: 0%/0%; one minute: 0%; five minutes: 0%
Time source is NTP, 22:30:29.381 JST Sat Dec 24 2011
BGP table version is 3393, local router ID is PE1-IP
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:10 (default for vrf CUSTOMER)
*>i1.1.1.0/30       PE3-IP             0    110      0 ?
* i                      PE3-IP             0    110      0 ?
* i2.2.2.0/30        PE4-IP            0    100      0 ?
*>i                     PE4-IP            0    100      0 ?
*> 3.3.3.0/30       0.0.0.0                  0         32768 ?
* i10.0.2.0/24      PE3-IP             0    110      0 65401 ?
*>i                      PE3-IP             0    110      0 65401 ?
*> 172.16.1.0/24    3.3.3.1                  0         32768 ?
PE1#
PE1#
PE2#
PE2#show ip bgp vpnv4 vrf CUSTOMER
Time source is NTP, 22:36:05.399 JST Sat Dec 24 2011
BGP table version is 5021, local router ID is PE2-IP
*>i1.1.1.0/30       PE3-IP             0    100      0 ?
* i                      PE3-IP             0    100      0 ?
* i2.2.2.0/30        PE4-IP            0    110      0 ?
*>i                     PE4-IP            0    110      0 ?
*> 4.4.4.0/30       0.0.0.0                  0         32768 ?
* i10.0.2.0/24      PE3-IP             0    100      0 65401 ?
*>i                     PE3-IP             0    100      0 65401 ?
*> 192.168.1.0      4.4.4.1                  0         32768 ?
PE2#
Hi Manoj
The config seems alright..However the output is little strange as when two different PEs are announcing the same route from Asia then why on PE1 and PE2 the prefix 10.0.2.0/24 is shown to be learnt from single PE only twice...
I think its bcoz of RRs coming in between..The RRs are selecting PE3 as the best route intermediately and announcing only PE3's routes further to PE1 and PE2..Interesting Issue to be looked at as I did not think of this before that RR's will be doing intermediate bgp best path selection..Now to overcome this issue we need to ensure that the RR's keep both the copies of route learnt from PE3 and PE4 and advertise the same to PE1/PE2..To do so we need to change the RD of vrf CUSTOMER on PE4 to 1:20 so that now the IPv4 Prefix 10.0.2.0/24 becomes two unqiue vpnv4 prefixes and hence RR reflects both of them to PE1/PE2..Now using the same community route-map inwards on PE1/PE2 we can match the export RT values of PE3/PE4 and set the local preference to 110..This will solve our requirement,
But we should make a note that changing the RD config on an already running VRF will result in disruption of services as the vrf needs to deleted and redefined..
Also on a side note when we are matching on the RT values on PE1/PE2 there is no need to set standard community on PE3/PE4 so we can get rid of the route-map config on PE3/PE4
Hope this helps to answer your query.
Varma
Message was edited by: Vaibhava Varma
Hi, Varma
Thank you for your comments. After changing the rd of PE4 to rd 1:20 it worked fine. Now the trafic is routed according to the way I wanted. Still testing the validity of the method and impact on the production network when the rd is changing and other things like redundancy.If I find any other issues ,I will  let you know.
Thanks again
Best regards
Manoj
Hi Manoj
Glad to hear that we finally arrived at a solution
Varma
Hi, Varma
As you suggested I removed standard community list and route-maps from PE3/PE4. After that  it didn't work properly. PE1/PE2 had their connected and statically mentioned routes only.
So I think below  standard community and route-maps are neccessary on PE3 & PE4. Little strange though.
PE3--
PE4---
regards
manoj
Hi Manoj
That should have not happened as we are not matching based on Standard Community but only extcommunity RT..
PE3/PE4 will be sending out the vpnv4 prefixes out to the MPLS Backbone by default so even if we removed the route-map there should have not been any issues.. Did you try soft claring MP-iBGP after removing route-map.
Varma
