installing BGP bestpaths into VRF instance
tim
Community Member
Hi!
Does anyone have any idea or knows the URL with subj configuration described? The most similar thing I've found @ cisco.com is "Configuring MPLS VPN", but actually I don't need MPLS. All I need is two (or more) full-view tables with unmixed bestpath routes (eachone in separate VRF).
Thank you.
Timothy.
tim
Community Member
In addition I would like to know, is it possible to set up a bgp-session between different VRFs on the same router?
Thank you.
Timothy.
mcros
Community Member
You will find a problem with BGP Router ID because both instances uses the same one.
We also needed this, and we ask Cisco to implement a new feature in which you could specify the BGP Router ID per VRF or per Neighbor.
Miguel
tim
Community Member
hmm...I see, but we still may use redistribution between VRFs for routing information exchange, am I right?
could you tell me an URL, where I can find inforamtion on how to configure per-VRF bgp-routers? Now I use to configure it intuitively 🙂
Timothy.
