Issue with EoMPLS between 7604 and 7200
shoaib.farhan
Community Member
We have upgraded our one router from 7200 to 7604 and bring up the EoMPLS between 7604 and 7200 VXR G2. Everything was working fine, but after power interruption all EoMPLS stop working. XCONNECT shows UP but traffic were not passing through it. Also CPU utilization increase from 12% to 42%. Any kind of help would be great.
Router:
Cisco 7604
RSP720-3CXL-10GE
ES+XC-20G3CXL
c7600rsp72043-advipservicesk9-mz.153-3.S6.bin
Cisco 7206 VXR G2
c7200p-advipservicesk9-mz.150-1.M3.bin
Some Troubleshooting Command Output
7604 Router
sh processes cpu
CPU utilization for five seconds: 33%/28%; one minute: 34%; five minutes: 33%
configuration
7600
int gi2/1
service instance 550 ethernet
    encapsulation dot1q 550
  rewrite ingress tag pop 1 symmetric
  xconnect x.x.x.x 550 encapsulation mpls
7200
interface GigabitEthernet2/0.550
 encapsulation dot1Q 550
 no cdp enable
 xconnect y.y.y.y 550 encapsulation mpls
7200 End
7200#sh mpls l2transport vc 550 detail
Local interface: Gi2/0.550 up, line protocol up, Eth VLAN 550 up
  Destination address: y.y.y.y, VC ID: 550, VC status: up
    Output interface: Gi0/2, imposed label stack {1933 51}
    Preferred path: not configured
    Default path: active
    Next hop: 116.212.104.18
  Create time: 00:22:57, last status change time: 00:17:10
  Signaling protocol: LDP, peer y.y.y.y:0 up
    Targeted Hello: x.x.x.x(LDP Id) -> y.y.y.y
    Status TLV support (local/remote)   : enabled/supported
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: no fault
    MPLS VC labels: local 2296, remote 51
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description: ** TEST-MJ-L2 **
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 366, send 1403
    byte totals:   receive 37462, send 142941
    packet drops:  receive 0, seq error 0, send 0
7200# sh mpls l2transport binding 550
  Destination Address: y.y.y.y,  VC ID: 550
    Local Label:  2296
        Cbit: 1,    VC Type: Eth VLAN,    GroupID: 0
        MTU: 1500,   Interface Desc: n/a
        VCCV: CC Type: CW [1], RA [2]
              CV Type: LSPV [2]
    Remote Label: 51
        MTU: 1500,   Interface Desc: ** TEST-MJ-L2 **
        VCCV: CC Type: CW [1], RA [2], TTL [3]
              CV Type: LSPV [2], Unkn [5]
7600
7604#sh mpls l2transport vc 550 detail
Local interface: Gi2/1 up, line protocol up, Eth VLAN 550 up
  Destination address: x.x.x.x, VC ID: 550, VC status: up
    Output interface: Gi2/10, imposed label stack {100 2296}
    Next hop: z.z.z.z
  Create time: 00:18:36, last status change time: 00:18:36
    Last label FSM state change time: 00:18:36
  Signaling protocol: LDP, peer x.x.x.x:0 up
    Targeted Hello: y.y.y.y(LDP Id) -> x.x.x.x, LDP is UP
    Graceful restart: configured and not enabled
    Non stop routing: not configured and not enabled
      LDP route watch                   : enabled
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: No fault
      Last local AC  circuit status sent: No fault
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 51, remote 2296
  Control Word: On (configured: autosense)
  SSO Descriptor: x.x.x.x/550, local label: 51
  Dataplane:
    SSM segment/switch IDs: 33411/426626 (used), PWID: 104
  VC statistics:
    transit packet totals: receive 1576, send 450
    transit byte totals:   receive 122506, send 50838
    transit packet drops:  receive 0, seq error 0, send 0
7600#sh mpls l2transport binding 550
  Destination Address: 116.212.104.252,VC ID: 550
    Local Label:  51
              CV Type: LSPV [2], BFD/Raw [5]
    Remote Label: 2296
              CV Type: LSPV [2]
Adam Vitkovsky
Level 7
Level 7
It might be the that the control-plane recovered but the forwarding plane got programed incorrectly after the reload.
You might want to check whether the HW is programed correctly with the appropriate label stack (label to reach the other end + VC label)
Try checking if there’s software forwarding going on:
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41120-highcpu-interrupts.html
adam
adam
