label problem
shan-cao
Level 3
Level 3
I have a mpls environment like following:
PE1 tdp<-->tdp P1 tdp<--->tdp P2 ldp<-->ldp PE2
PE1 can't establish the correct LSP to PE2. I use the command"sho mpls forwarding-table x.x.x.x"
x.x.x.x is the loopback address of PE2.
as following____>
M-FZY-7206-0A#sho mpls forwarding-table x.x.x.x
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
130 Untagged x.x.x.x/32 0 PO1/0 point2point
I can't see the tag used in outgoing. how to solve it?
Sincerely
I assume the command was run on PE1, right? This shows that you are receiving a routing advertisement for 211.92.128.50/32 and this is why you generate a local label for it. But you don't receive a label from PE1 for this prefix.
Is is possible you are doing label filtering on PE1
7 Replies 7
Could you please do a "sh mpls ldp dis" and "sh mpls ldp nei" on P1 and P2 to make sure your TDP and LDP sessions are up.
Strangely, both P1 and P2 can see the lable of outgoing about PE2 through the commmand"sho mpls forwording-table x.x.x.x". In addition, P2 can establish the ldp neighbor well to the PE2. what's problem about this issue?
Sincerely
The problem is either that PE1 doesn't have a TDP neighbor relationship with P1 or it doesn't receive a routing update for the PE2 loopback address. If the problem is the latter, you should still get a label on PE1 for PE2 loopback. Do a "sh mpls ldp binding" to find out if it is the case.
PE1 should have the good TDP neighbor relationship with P1 because other PE not PE2 can communicate with PE1 in mpls environment.
Question is how to analyze the display by using command"sh mpls ldp binding". My display is following:
M-GJSH-7206-0A#sho mpls ldp bind 211.92.128.50 32
tib entry: 211.92.128.50/32, rev 1550
local binding: tag: 82
M-GJSH-7206-0A#sho mpls for
M-GJSH-7206-0A#sho mpls forwarding-table 211.92.128.50
82 Untagged 211.92.128.50/32 0 PO1/0 point2point
211.92.128.50 is the loopback address of PE2.
Could you give me any suggestion about my issue?
Sincerely
There was not label filtering on PE1. I just add these configurations on PE1:
no mpls ldp logging neighbor-changes
no tag-switching advertise-tags
tag-switching advertise-tags for 80
tag-switching tdp router-id Loopback0
access-list 80 permit 211.92.128.0 0.0.0.63
the 7200's version is System image file is "disk0:c7200-js-mz.122-12.bin"
Hi,thank you very much. I have solved my problem.
P1 have limited the tag advertising for PE1. so I removed the limit from P1. everything is ok.
Sincerely
