MPLS -MP-BGP with VRF configuration
R Manjunatha
Level 3
Level 3
I configured the MP-BGP PE1 and PE3 Routers with VRF to segregate the customer's routes and CE1 and CE6 Routers default static route towards PE Routers. I could not be able to see any output after this command sh ip bgp vpnv4 all summary in both the PE routers and unable to ping between PE routers loopback address.
 PE-1#ping 60.60.60.60
Sending 5, 100-byte ICMP Echos to 60.60.60.60, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
PE-6#ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
U.U.U
PE-1# sh ip bgp summ
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.20.70.70 4 100 220 222 2 0 0 03:17:46
PE-1#SH IP ROU VRF CA-1
Routing Table: CA-1
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/32 is subnetted, 1 subnets
S 10.10.10.10 [1/0] via 172.16.1.1
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.1.0/30 is directly connected, Ethernet0/3
L 172.16.1.2/32 is directly connected, Ethernet0/3
hostname PE-1
boot-start-marker
boot-end-marker
vrf definition CA-1
rd 500:1
route-target export 500:1
route-target import 500:1
address-family ipv4
exit-address-family
interface Loopback0
ip address 10.20.10.10 255.255.255.255
interface Ethernet0/0
ip address 10.20.1.1 255.255.255.252
duplex auto
mpls label protocol ldp
mpls ip
interface Ethernet0/1
ip address 10.20.1.5 255.255.255.252
duplex auto
mpls ip
interface Ethernet0/2
no ip address
shutdown
duplex auto
mpls ip
interface Ethernet0/3
vrf forwarding CA-1
ip address 172.16.1.2 255.255.255.252
duplex auto
router ospf 10
router-id 1.1.1.1
network 10.20.0.0 0.0.255.255 area 0
router bgp 100
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 10.20.70.70 remote-as 100
neighbor 10.20.70.70 update-source Loopback0
address-family ipv4
network 10.20.10.10 mask 255.255.255.255
neighbor 10.20.70.70 activate
neighbor 10.20.70.70 send-community extended
neighbor 10.20.70.70 next-hop-self
exit-address-family
address-family ipv4 vrf CA-1
redistribute connected
redistribute static
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf CA-1 10.10.10.10 255.255.255.255 172.16.1.1
PE-3#sh ip bgp summary
10.20.10.10 4 100 230 228 2 0 0 03:25:14
PE-3#sh ip ROUte VRf CA-2
Routing Table: CA-2
60.0.0.0/32 is subnetted, 1 subnets
S 60.60.60.60 [1/0] via 172.16.2.2
C 172.16.2.0/30 is directly connected, Ethernet0/2
L 172.16.2.1/32 is directly connected, Ethernet0/2
hostname PE-3
boot-start-marker
boot-end-marker
vrf definition CA-2
rd 500:1
address-family ipv4
exit-address-family
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
mpls label range 800 899
interface Loopback0
ip address 10.20.70.70 255.255.255.0
ip address 10.20.1.22 255.255.255.252
duplex auto
mpls ip
ip address 10.20.1.38 255.255.255.252
duplex auto
mpls ip
vrf forwarding CA-2
ip address 172.16.2.1 255.255.255.252
duplex auto
no ip address
shutdown
duplex auto
router ospf 10
router-id 7.7.7.7
router bgp 100
neighbor 10.20.10.10 remote-as 100
neighbor 10.20.10.10 update-source Loopback0
address-family ipv4
network 10.20.70.70 mask 255.255.255.255
neighbor 10.20.10.10 activate
neighbor 10.20.10.10 send-community extended
neighbor 10.20.10.10 next-hop-self
exit-address-family
address-family ipv4 vrf CA-2
redistribute static
exit-address-family
no ip http server
ip route vrf CA-2 60.60.60.60 255.255.255.255 172.16.2.2
ipv6 ioam timestamp
CE-1
interface Loopback0
ip address 10.10.10.10 255.255.255.255
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
ip address 172.16.1.1 255.255.255.252
duplex auto
no ip address
shutdown
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.2
CE-6
interface Loopback0
ip address 60.60.60.60 255.255.255.255
no ip address
shutdown
duplex auto
ip address 172.16.2.2 255.255.255.252
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.2.1
@R Manjunatha,
on you router bgp instance you need  address-family vpnv4 configured !
Configure under this address-family neighborship.
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/iosxr/ncs5xx/l3vpn/70x/b-l3vpn-cg-70x-ncs540/b-l3vpn-cg-70x-ncs540_chapter_01.html.xml
--- How MPLS L3VPN Works
Best regards
6 Replies 6
M02@rt37
Hello @R Manjunatha
Do
PE-1#ping 60.60.60.60 vrf <VRF NAME>
also there is an issue with static redistribution
Please share output on PE-01 of that command:
#show ip bgp vpnv4 vrf CA-1
Best regards
@R Manjunatha,
Best regards
Yes...there was a misconfiguration. I configured address-family vpnv4.
But I am unable to ping CE1 to CE6
Routing Table: CA-1
B 60.60.60.60 [200/0] via 10.20.70.70, 00:21:07
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
B 172.16.2.0/30 [200/0] via 10.20.70.70, 00:21:07
PE-1#PING VRF CA-1 60.60.60.60
PE-1#show ip bgp vpnv4 vrf CA-1
BGP table version is 7, local router ID is 10.20.10.10
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 500:1 (default for vrf CA-1)
*> 10.10.10.10/32 172.16.1.1 0 32768 ?
*>i 60.60.60.60/32 10.20.70.70 0 100 0 ?
*> 172.16.1.0/30 0.0.0.0 0 32768 ?
*>i 172.16.2.0/30 10.20.70.70 0 100 0 ?
PE-3#show ip bgp vpnv4 vrf CA-2
BGP table version is 7, local router ID is 10.20.70.70
t secondary path,
Route Distinguisher: 500:1 (default for vrf CA-2)
*>i 10.10.10.10/32 10.20.10.10 0 100 0 ?
*> 60.60.60.60/32 172.16.2.2 0 32768 ?
*>i 172.16.1.0/30 10.20.10.10 0 100 0 ?
*> 172.16.2.0/30 0.0.0.0 0 32768 ?
Ok @R Manjunatha,
do
PE-1#PING VRF CA-1 60.60.60.60 source 172.16.1.2
Best regards
R Manjunatha
Level 3
Level 3
Thank you. it's working ...now.
Great!
You're very welcome @R Manjunatha.
Best regards
