MPLS-TE Tunnel (FRR) Issue
qasey_shiz
Need some discussion on MPLS - TE tunnel issue.
One of Tunnel with FRR configured, creates problem after a while affects the traffic running on the link until I shut the tunnel manually.
Configs are ok because same configurations made for different cities to authenticate to a AAA server located in one of city.
following is the generic diagram and complete config for respective links in all 3 cities but the tunnel on link highlighted with RED arrow creates problem after a while not at once until I shut the tunnel,
The Platform is Cisco CISCO7609-S and all links are on 7600-SIP-400 module
interface GigabitEthernet2/2/0
description *** Physical Interface ***
dampening
mtu 9216
ip address x.x.x.x x.x.x.x
no ip redirects
no ip proxy-arp
ip ospf message-digest-key 1 md5 7 xxx
ip ospf network point-to-point
load-interval 30
carrier-delay msec 0
negotiation auto
mpls traffic-eng tunnels
mpls traffic-eng backup-path Tunnel2300
mpls ip
service-policy output egress_policy
hold-queue 4096 in
hold-queue 4096 out
ip rsvp bandwidth percent 95
ip rsvp signalling dscp 48
end
x.x.x.x#sh running-config int tun 1300
Building configuration...
Current configuration : 377 bytes
interface Tunnel1300
description *** Primary Tunnel ***
ip unnumbered Loopback0
shutdown
mpls ip
tunnel destination x.x.x.x
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng path-option 10 explicit name path-1300
tunnel mpls traffic-eng fast-reroute
end
x.x.x.x#sh running-config int tun 2300
Current configuration : 332 bytes
interface Tunnel2300
description *** Backup Tunnel ***
shutdown
mpls ip
tunnel mpls traffic-eng path-option 10 explicit name path-2300
tunnel mpls traffic-eng record-route
end
Nagendra Kumar Nainar
Hi Qaiser,
Can you explain the problem you are facing?. Is the traffic geting black holed or tunnel goes down/flaps?. Is this tunne single hop or multihopped to destination?.
Nagendra
Hi Nagendra,
Tunnel status remain up FRR stay ready but traffic become black holed and the tunnel is single hop destination, you can see the attached diagram
Issue was figured out, the traffic was dropping dut to EF tagged traffic in the service policy applied under the physical interface.
The limit of EF tagged traffic was defined less as per actual traffic which was causing drop in peak hours
