SP: FAILED to write to DS1338 RTC device
j2cs_1977
HI all,
Somebody knows, How Can I founf a soluction for this logs?
9w4d: SP: FAILED to write to DS1338 RTC device
3w2d: SP-STDBY: FAILED to write to DS1338 RTC device
29w4d: SP: FAILED to write to DS1338 RTC device
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 20-Sep-11 19:45 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD7, RELEASE SOFTWARE (fc1)
rb5-uiomatriz uptime is 29 weeks, 6 days, 17 hours, 21 minutes
Uptime for this control processor is 29 weeks, 6 days, 17 hours, 12 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 16:41:05 EST Tue Apr 16 2013
System image file is "sup-bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRD7.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 917504K/65536K bytes of memory.
Processor board ID FOX1534GEC2
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
16 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
0 Replies 0
