Unidirectional traffic in one way over multiple physical links
ThomasD86
I am working with the following topology:
Between PE#1 and PE#2 an iBGP neighborship exists, both PEs have an OSPF neighborship with the P router. Recently, we've added a second physical link between P and PE#2 but we observed an uneven balancing of the traffic after this operation.
Traffic from PE#1 to PE#2 that transits over P1, will only always utilize the first link (.86->.87) whereas traffic from PE#2 to PE#1 will be balanced across all 3 links.
Looking at the P1 router, I see that the route to PE#2 is known from both of the links:
Routing entry for 172.16.0.161/32
  Known via "ospf 1", distance 110, metric 26, type intra area
  Installed Jan 11 01:09:18.068 for 1w1d
  Routing Descriptor Blocks
    172.16.2.87, from 172.16.0.161, via FortyGigE0/0/0/13
      Route metric is 26
    172.16.2.201, from 172.16.0.161, via FortyGigE0/0/0/14
      Route metric is 26
 However, looking at the mpls forwarding table:
show mpls forwarding prefix 172.16.0.161/32
Fri Jan 19 15:57:12.555 CET
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
24324  Pop         172.16.0.161/32    Fo0/0/0/13   172.16.2.87     13079621827
 and the CEF:
show cef 172.16.0.161
Fri Jan 19 15:57:48.195 CET
172.16.0.161/32, version 49063, internal 0x1000001 0x30 (ptr 0xa1285d40) [1], 0x0 (0x90919418), 0xa20 (0xa15b6ef8)
 Updated Jan 11 01:09:18.077
 local adjacency to FortyGigE0/0/0/13
 Prefix Len 32, traffic index 0, precedence n/a, priority 3
   via 172.16.2.87/32, FortyGigE0/0/0/13, 3 dependencies, weight 0, class 0 [flags 0x0]
    path-idx 0 NHID 0x0 [0xa0d7a6a8 0x0]
    next hop 172.16.2.87/32
    local adjacency
     local label 24324      labels imposed {ImplNull}
   via 172.16.2.201/32, FortyGigE0/0/0/14, 6 dependencies, weight 0, class 0 [flags 0x0]
    path-idx 1 NHID 0x0 [0xa0d7bc08 0x0]
    next hop 172.16.2.201/32
    local adjacency
     local label 24324      labels imposed {None}
 The first thing I notice is that if for the link over Fo0/0/0/13 PE#2 passed to the P router an impnull label, it did not do the same for the link over Fo0/0/0/14.
Looking at PE#2:
show mpls forwarding-table 172.16.0.163
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
2531       24361      172.16.0.163/32  0             Fo0/2/8    172.16.2.200
           24361      172.16.0.163/32  0             Fo0/2/0    172.16.2.86
           24359      172.16.0.163/32  0             Fo0/2/4    172.16.2.88
Still on PE#2, looking at the forwarding-table towards the P1 router:
show mpls forwarding-table 172.16.0.20
230        Pop Label  172.16.0.20/32   54268855      Fo0/2/0    172.16.2.86
           Pop Label  172.16.0.20/32   6332583       Fo0/2/8    172.16.2.200
 So it seems that PE#2 is passing the correct label however it seems that this is not reflected on the P1 router. What could be the cause of this?
Thanks for helping
you need to check the routing table in both P and PE
one have equal cost multi path other not have
I think this issue is mismatch of cost in both end
filopeter
this is an expected behaviour on P1 router. It is an MPLS P (LSR) router, it just swaps labels according the mpls forwarding table. There must be a clear statement what to do with the incoming labels in the lfib (mpls forwarding table).
To achieve load-balancing consider to use either different bgp next-hop per l3vpn on PE2, or FAT labels between P1 and PE2 in case of l2vpn service.
