VRF selector using PBR or Source IP address
ellemen
Community Member
Could anyone can tell which is the better choice of VRF selector using PBR or Source IP address? From Cisco doc, VRF selection based on Source take advance over PBR. My feeling is that PBR may match more criterias than just match source IP address.
I would personally use the "VRF selection based on source IP address" only where the "VRF selection using PBR" is not available since the latter is a superset of the former.
Hope this helps,
